How to test positive ion?
  1. Mar 13, 2012 #1
    http://www.ebay.com.hk/itm/370583387771?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
    I have tested it using a 1.3v battery,
    Once I have switch "ON" this tester, Let the positive end of battery touch on the square metal of the front panel and let the rear square metal of this tester touch on the negative end of battery. It works and display negative value -13xx, but
    when the positive end of battery touch on the rear square metal and let the square metal of the front panel of this tester touch on the negative end of battery. It also display close to zero value, it seems to me that this Air Ion Tester can only display negative values.
    It cannot be able to display positive value at all. Will it be correct to test positive ion using above approach? or does my item not funciton properly?
    I would like to confirm whether my item works properly or not.
    Does anyone have any suggestions?
    Thanks in advance for any suggestions
Draft saved Draft deleted
