Python How to use outputs from previous time steps in tensorflow?
In the following example, there are three time series and I want to predict another time series y which is a function of the three. How can I use four inputs to predict the time series where the fourth input is the output at previous time step?
Python:
    import tensorflow as tf
    import numpy as np
    import pandas as pd
    #clean computation graph
    tf.reset_default_graph()
    tf.set_random_seed(777)  # reproducibility
    np.random.seed(0)
    import matplotlib.pyplot as plt
    def MinMaxScaler(data):
        numerator = data - np.min(data, 0)
        denominator = np.max(data, 0) - np.min(data, 0)
        # noise term prevents the zero division
        return numerator / (denominator + 1e-7)
    class generate_data(object):
        def __init__(self, data_len,  in_series, y_pred, seq_lengths, method='sum' ):
            self.data_len = data_len
            self.data = None
            self.in_series = in_series #number of input series
            self.y_pred = y_pred  #number of final outputs from model
            self.seq_lengths = seq_lengths
            self.method = method
        def _f(self, x):
            y = 0
            result = []
            for _ in x:
                result.append(y)
                y += np.random.normal(scale=1)
            return np.array(result)
        def _runningMean(self, x, N):
            return np.convolve(x, np.ones((N,))/N)[(N-1):]
        def sine(self):
            DATA = np.zeros((self.data_len, self.in_series))
            xx = [None]
            data_0 = np.sin(np.arange(self.data_len*self.in_series))
            xx = data_0.reshape(self.data_len, self.in_series)
            DATA[:,0: self.in_series] = xx
            y = self._get_y(DATA)
            return xx,y, DATA
        def _get_y(self, xx):
            if self.method=='sum':
                yy = np.array([np.sum(xx[i,:]) for i in range(np.shape(xx)[0])])
            elif self.method == 'mean':
                  yy = np.array([np.mean(xx[i,:]) for i in range(np.shape(xx)[0])])
            elif self.method == 'self_mul':
                yy = np.array([np.prod(xx[i,:]) for i in range(np.shape(xx)[0])])
            elif self.method == 'mean_mirror':
            return yy
        def normalize(self, xx1,yy1):
            yy = [None]*len(yy1)
            YMinMax = {}
            xx = MinMaxScaler(xx1)
            for i in range(self.y_pred):
                YMinMax['ymin_' + str(i)] = np.min(yy1[0])
                YMinMax['ymax_' + str(i)] = np.max(yy1[0])
                yy[i] = MinMaxScaler(yy1[0])
            setattr(self, 'YMinMax', YMinMax)
            return xx,yy
        def create_dataset(self, xx, yy):
            '''creates a dataset consisting of windows for x and y data'''
            dataX = self._build_input_windows(xx, self.seq_lengths)
            if self.y_pred > 1:
                pass
            elif self.y_pred > 1 and self.seq_lengths != any(self.seq_lengths):
                pass
            else:
                dataY = self._build_y_windows(yy[0] , self.seq_lengths)
            return dataX, dataY
        def _build_input_windows(self, time_series, seq_length):
            dataX = []
            for i in range(0, len(time_series) - seq_length):
                _x = time_series[i:i + seq_length, :]
                dataX.append(_x)
            return np.array(dataX)
        def _build_y_windows(self, iny, seq_length):
            dataY = []
            for i in range(0, len(iny) - seq_length):
                _y = iny[i + seq_length, ]  # Next close price
                dataY.append(_y)
            return  np.array(dataY)
        def TrainTestSplit(self, dataX, dataY, train_frac):
            train_size = int(len(dataY) * train_frac)
            trainX, testX = np.array(dataX[0:train_size]), np.array(dataX[train_size:len(dataX)])
            trainY, testY = np.array(dataY[0:train_size]), np.array(dataY[train_size:len(dataY)])
            trainY = trainY.reshape(len(trainY), 1)
            testY = testY.reshape(len(testY), 1)
            return trainX, trainY, testX, testY, train_size
    #training/hyper parameters
    tot_epochs = 500
    batch_size = 32
    learning_rate = 0.01
    seq_lengths = 5  #sequence lengths/window size for  RNN
    rnn_inputs = 3 # no of inputs for  RNN
    y_pred = 1
    data_length = 105  #this can be overwritten or useless
    gen_data = generate_data(data_length,  rnn_inputs, y_pred, seq_lengths, 'sum')
    xx,yy,data_1 = gen_data.sine()
    train_frac = 0.8
    xx1,yy1 = gen_data.normalize(xx,[yy])
    dataX, dataY = gen_data.create_dataset(xx1,yy1)
    trainX, trainY, testX, testY, train_size = gen_data.TrainTestSplit( dataX, dataY, train_frac)
    keep_prob = tf.placeholder(tf.float32)
    x_placeholders = tf.placeholder(tf.float32, [None, 5, 3])
    Y =  tf.placeholder(tf.float32, [None, 1])
    with tf.variable_scope('scope0'):  #defining  RNN
        cell = tf.contrib.rnn.BasicLSTMCell(num_units= 7, state_is_tuple=True, activation=tf.tanh)
        outputs1, _states = tf.nn.dynamic_rnn(cell, x_placeholders, dtype=tf.float32)
        Y_pred1 = tf.contrib.layers.fully_connected(outputs1[:, -1], 1, activation_fn=None)
    Y_pred = Y_pred1
    ## cost/loss
    loss = tf.reduce_sum(tf.square(Y_pred - Y))  # sum of the squares
    ## optimizer
    optimizer = tf.train.AdamOptimizer(learning_rate)
    train = optimizer.minimize(loss)
    ## RMSE
    targets = tf.placeholder(tf.float32, [None, 1])
    predictions = tf.placeholder(tf.float32, [None, 1])
    rmse = tf.sqrt(tf.reduce_mean(tf.square(targets - predictions)))
    with tf.Session() as sess:
        saver = tf.train.Saver(max_to_keep=41)
        writer = tf.summary.FileWriter('./laos_2out/cnntest', sess.graph)
        init = tf.global_variables_initializer()
        sess.run(init)
        # Training step
        for epoch in range(tot_epochs):
          total_batches = int(train_size / batch_size)  ##total batches/ no. of steps in an epoch
          #for batch in range(total_batches):
          _, step_loss = sess.run([train, loss], feed_dict= {x_placeholders:trainX, Y:trainY, keep_prob:0.5} )
    #    # evaluating on test data
        test_predict = sess.run(Y_pred, feed_dict= {x_placeholders:testX, Y:trainY, keep_prob:0.5} )
        #evaluating on training data
        train_predict = sess.run(Y_pred, feed_dict={x_placeholders:trainX, Y:trainY, keep_prob:0.5})
        rmse_val = sess.run(rmse, feed_dict={targets: testY, predictions: test_predict})
        print("RMSE: {}".format(rmse_val))
        # Plot predictions
        fig, (ax1,ax2) = plt.subplots(1,2, sharey=True)
        fig.set_figwidth(14)
        fig.set_figheight(5)
        ax2.plot(testY, 'b', label='observed')
        ax2.plot(test_predict, 'k', label='predicted')
        ax2.legend(loc="best")
        ax2.set_xlabel("Time Period")
        ax2.set_title('Testing')
        ax1.plot(trainY, 'b', label='observed')
        ax1.plot(train_predict, 'k',label= 'predicted')
        ax1.legend(loc="best")
        ax1.set_xlabel("Time Period")
        ax1.set_ylabel("discharge (cms)")
        ax1.set_title('Training')
        plt.show()
I have googled other similar answers which make use of tf.nn.raw_rnn but in those cases only the predicted output at previous time steps is used but I want the predicted output at previous timesteps plus other three inputs to be used for prediction.
1,416
Thanks for the thread! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post? The more details the better.
Want to reply to this thread?
"How to use outputs from previous time steps in tensorflow?" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
