How to use part A in order to solve pard B
  • Thread starter transgalactic
Can you say, "overthinking"? Try the multiplication, and see what you get.i did the multiplication and get the same matrixOK, but if you get the same matrix, then the equations for x1, x2, and x3 are trivial. What are they?i cannot understandcan you explainOK, so you have this matrix equation:\begin{bmatrix} 13x_1 &-42x_1 &0 \\ 7x_2 &-22x_2 &0 \\ 0&0&3x_3 \end{bmatrix} = \begin{bmatrix} 13x_1 &-42
transgalactic
1,395
part A(i managed to solve it):
X is a variable of [tex]M_{3X3}[/tex]
[tex]
D=\bigl(\begin{smallmatrix}
\lambda_1 &0 &0 \\
0 & \lambda_2& 0\\
0&0 &\lambda_3
\end{smallmatrix}\bigr)
[/tex]
where
[tex]\lambda_1,\lambda_2,\lambda_3[/tex] are different rational numbers.
solve XD=DX for X.
solution:
[tex]
x_{11}& x_{12} & x_{13}\\
x_{21}&x_{22} &x_{23} \\
x_{31}&x_{32} &x_{33}
\end{smallmatrix}\bigr)\bigl(\begin{smallmatrix}
\lambda_1 &0 &0 \\
0 & \lambda_2& 0\\
0&0 &\lambda_3
\end{smallmatrix}\bigr)=\bigl(\begin{smallmatrix}
\lambda_1 &0 &0 \\
0 & \lambda_2& 0\\
0&0 &\lambda_3
[/tex]
so i get
[tex]
x_{11}\lambda_1& x_{12}\lambda_2 & x_{13}\lambda_3\\
x_{21}\lambda_1&x_{22}\lambda_2 &x_{23}\lambda_3 \\
x_{31}\lambda_1&x_{32}\lambda_2 &x_{33}\lambda_3
x_{11}\lambda_1& x_{12}\lambda_1 & x_{13}\lambda_1\\
x_{21}\lambda_2&x_{22}\lambda_2 &x_{23}\lambda_2 \\
x_{31}\lambda_3&x_{32}\lambda_3 &x_{33}\lambda_3
\end{smallmatrix}\bigr)[/tex]
so for both side to be equal X must be of diagonal structure
every member must be zero except the diagonal
because the lambda values are given as different.
part B(the one that i don't understand):
[tex]
A=\bigl(\begin{smallmatrix}
13& -42 & 0\\
7&-22 &0\\
0&0&3
what is the solution space of XA=AX (use part A)??
i tried
XA=AX
XPDP^-1=PDP^-1X (multiplying by p from the right)
XPDP^-1P=PDP^-1XP
XPD=PDP^-1XP (multiplying by p^-1 from the left)
P^-1XPD=P^-1PDP^-1XP
P^-1XPD=DP^-1XP
another thing i could find is the eigen values of the matrix
i got
[tex]\lambda_1=-1[/tex] and [tex]\lambda_2=-8[/tex]
and [tex]\lambda_3=3[/tex]
P^-1AP[tex]=\bigl(\begin{smallmatrix}
-1& 0 & 0\\
0&-8 &0\\
0&0&3
i can substitute A by X but what's to do next??
For the a part, you don't show what you actually got for matrix X, which is a 3 x 3 diagonal matrix with x11, x22, and x33 on the diagonal.
For the b part, you're given a matrix A. The most obvious start would be to carry out the products AX and XA and see what you get.
X matrix are all the matrices which are diagonalized
i was told to use part A not do a straight multiplication
Apparently you were also told to use part a, but you're not using it if you don't show what you get for matrix X. Regardless of what you were told, if I had to do this problem, I would multiply AX and XA and see what I got.
in part A in order for the equality to be true
x must look as
[tex]
x_{11}\lambda_1&0 & 0\\
0&x_{22}\lambda_2 &0 \\
0&0 &x_{33}\lambda_3
[/tex]
does it help in using part B
after i got this
P^-1XPD=DP^-1XP
No, your matrix X has to look like this:
[tex]\bigl(\begin{smallmatrix} x_{11}&0 & 0\\ 0&x_{22} &0 \\ 0&0 &x_{33} \end{smallmatrix}\bigr)[/tex]
What you just showed was XD or DX, not X.
You're given matrix A (you showed it in your first post). Use what you've found about matrix X to find the solution space of AX = XA.
i get this expression
P^-1XPD=DP^-1XP
x is diagonal
P^-1XP is a formula for diagonalizing a matrix
what solution i need to find??
P^-1XPD=DP^-1XP
Why are you still messing around with this? Do you know what problem you're trying to solve? It's not evident to me that you do.
transgalactic said:
x is diagonal
Do you want me to hold your hand? Look at my post #6.
you are right
i don't understand what i am asked to find
i need to find X
OK, here's X
And here's A
[tex]\bigl(\begin{smallmatrix} 13& -42 & 0\\ 7&-22 &0\\ 0&0&3 \end{smallmatrix}\bigr)[/tex]
Put them in the equation AX = XA. What do you get? The equations in x11, x22, and x33 will determine the solution space for the equation AX = XA.
Regarding my previous post, I haven't worked this problem through, but I'm just trying to show you my thinking process. It's possible that what I've proposed is a deadend, but you can't know that until you've tried it.
Now, why is it that I know what you're asked to find? I looked at the problem you showed in your first post. You have to know what the problem is, and what are the relevant definitions for your problem.
[tex]
\bigl(\begin{smallmatrix} 13& -42 & 0\\ 7&-22 &0\\ 0&0&3 \end{smallmatrix}\bigr)=\bigl(\begin{smallmatrix} 13x_{11}&-42x_{11} & 0\\ 7x_{22}&-22x_{22} &0 \\ 0&0 &3x_{33} \end{smallmatrix}\bigr)
[/tex]
[tex]
\bigl(\begin{smallmatrix} 13& -42 & 0\\ 7&-22 &0\\ 0&0&3 \end{smallmatrix}\bigr)\bigl(\begin{smallmatrix} x_{11}&0 & 0\\ 0&x_{22} &0 \\ 0&0 &x_{33} \end{smallmatrix}\bigr)
[/tex]
from both multiplication i get the same matrix
what to do now
AX and XA don't come out the same. Try again. Since there are only three nonzero entries in X, you're less prone to making errors if you write it like this:
[tex]X = \bigl[\begin x_{1}&0 & 0\\ 0&x_{2} &0 \\ 0&0 &x_{3} \end \bigr][/tex]
i can't see my mistake
[tex]
\begin{bmatrix}
x_1 &0 &0 \\
0&x_2 &0 \\
0& 0& x_3
\end{bmatrix}
\begin{bmatrix}
13 &-42 &0 \\
7&-22 &0 \\
0& 0& 3
\end{bmatrix}
\begin{bmatrix}
13x_1 &-42x_1 &0 \\
7x_2 &-22x_2 &0 \\
0& 0& 3x_3
\end{bmatrix}\\
[/tex]
same here
[tex]
\begin{bmatrix}
13 &-42 &0 \\
7&-22 &0 \\
0& 0& 3
\end{bmatrix}
\begin{bmatrix}
x_1 &0 &0 \\
0&x_2 &0 \\
0& 0& x_3
\end{bmatrix}
\begin{bmatrix}
13x_1 &-42x_1 &0 \\
7x_2 &-22x_2 &0 \\
0& 0& 3x_3
\end{bmatrix}\\
[/tex]
[tex]
\begin{bmatrix}
x_1 &0 &0 \\
0&x_2 &0 \\
0& 0& x_3
\end{bmatrix}
\begin{bmatrix}
13 &-42 &0 \\
7&-22 &0 \\
0& 0& 3
\end{bmatrix}
\begin{bmatrix}
13x_1 &-42x_1 &0 \\
7x_2 &-22x_2 &0 \\
0& 0& 3x_3
\end{bmatrix}\\
[/tex]
same here
The errors (two of them) are in the multiplication below.
transgalactic said:
[tex]
\begin{bmatrix}
13 &-42 &0 \\
7&-22 &0 \\
0& 0& 3
\end{bmatrix}
\begin{bmatrix}
x_1 &0 &0 \\
0&x_2 &0 \\
0& 0& x_3
\end{bmatrix}
\begin{bmatrix}
13x_1 &-42x_1 &0 \\
7x_2 &-22x_2 &0 \\
0& 0& 3x_3
\end{bmatrix}\\
[/tex]
Here we are at post 16, still futzing around with something that I suggested you should try all the way back in post 2. I have to say it's pretty frustrating for me. I can only hope that you start to pick up on some of the guidance that I and others on this forum are trying to provide you so that you can do some of this on your own.
1. How do I determine which part A to use for solving part B?
The first step in using part A to solve part B is to clearly define the problem and identify the key components. Then, you can research and analyze different options for part A and determine which one is most suitable for solving part B.
2. Can I use multiple parts A to solve part B?
Yes, it is possible to use multiple parts A to solve part B. This approach is often used when one part A is not sufficient on its own, or when different parts A can complement each other to provide a more comprehensive solution.
3. How do I integrate part A and part B in the solution?
The integration of part A and part B in the solution will depend on the specific problem at hand. In general, it is important to clearly define the roles and functions of each part and how they work together to achieve the desired outcome.
4. What are some common pitfalls to avoid when using part A to solve part B?
One common pitfall is assuming that part A will automatically solve part B without proper analysis and evaluation. It is important to thoroughly understand the capabilities and limitations of part A, and consider potential challenges or limitations in using it to solve part B.
5. Are there any alternatives to using part A for solving part B?
Yes, there may be alternatives to using part A for solving part B. It is always important to consider and evaluate different options to determine the most effective and efficient solution. Additionally, as technology and knowledge advance, new alternatives may emerge, so it is important to stay updated and open-minded in problem-solving processes.
  • Quantum Physics
  • Precalculus Mathematics Homework Help
