Homework Help: How would I solve sinѲ=sin2Ѳ?
  1. Sep 1, 2014 #1
    sinΘ=sin2Θ
    2. Relevant equations
    Double-angle forumla...
    sin2Θ=2sinΘcosΘ
    sinΘ=2sinΘcosΘ
    sinΘ
    3. The attempt at a solution
    sinΘ=2sinΘcosΘ
    sinΘ-2sinΘcosΘ=0
    sinΘ(1-2cosΘ)=0
    Now I'm getting stuck because 1-2cosΘ is not an identity of any sort.
    Any help would be appreciated...thanks!
  3. Sep 1, 2014 #2
    Nathanael
    Instead of subtracting; what about dividing both sides by sinΘ?
    Edit:
    You could divide right here, too. (zero divided by anything* is still zero)
    *anything except zero
  4. Sep 1, 2014 #3
    I'll try that!
    Edit:
    AH I see it
  5. Sep 1, 2014 #4
    Mark44
    Staff: Mentor
    This is not a good idea. Dividing by sinθ causes you to lose solutions for which sinθ = 0.
  6. Sep 1, 2014 #5
    Nathanael
    Actually, your way is better
    It is better to set it up like this because this shows all of the solutions. (I overlooked this in my first post.)
    When is sinΘ(1-2cosΘ) equal to zero? (There are two solutions)
    edit:
    Yes I just realized this :redface: thank you
    edit#2:
    I had a feeling you would point this out too :biggrin: I couldn't think of a concise way to say it. (I meant two ways)
    Maybe I should stay out of the math section :tongue:
  7. Sep 1, 2014 #6
    Mark44
    Staff: Mentor
    Doesn't need to be. You're on the right track. If the product above equals zero, that means that either sinθ = 0 or 1 - 2cosθ = 0.
  8. Sep 1, 2014 #7
    Mark44
    Staff: Mentor
    There are LOTS more than two solutions...
  9. Sep 1, 2014 #8
    nrqed
    You have the product of two functions of Θ. The result is zero when either sinΘ or 1-2cosΘ is zero.
    This occurs at what angles? (As for 1-2cosΘ=0, just isolate the angle. Do you see how to do that?)
  10. Sep 1, 2014 #9
    Let's see...
    I could do sinΘ=0 or 1-2cosΘ=0
    sinΘ=0
    Θ= (pi)/2
    1-2cosΘ=0
    2cosΘ=-1
    cosΘ=-1/-2
    cosΘ=1/2
    Θ=5(pi)/3 or (pi)/3
    I see that if I do it this way, instead of dividing out the sine, I capture one more solution.
    Very helpful...thank you!
  11. Sep 1, 2014 #10
    Mark44
    Staff: Mentor
    Since there are no restrictions on θ (or at least none shown in your OP), you should add integer multiples of 2π to each of your solutions to capture all possible solutions.
  12. Sep 1, 2014 #11
    nrqed
    Watch out, ## \sin(\theta) =0 ## at ##\theta = \ldots, - \pi, 0 , \pi, \ldots ##,
    not at ##\theta = \pi/2##!
  13. Sep 2, 2014 #12
    BvU
    2017 Award
    Watch out some more !
    sinΘ(1-2cosΘ)=0 ##\Leftrightarrow ## sinΘ=0 ##\vee ## (1-2cosΘ)=0
    First one: sinΘ=0 ##\Leftrightarrow ## sinΘ=sin(0) ##\Leftrightarrow## Θ = 0 + 2n∏ ##\vee ## Θ = ∏ - 0 + 2n∏ ##\Leftrightarrow## Θ = n∏ (with n an integer)
    Now you do the second one. And don't write 1-2cosΘ=0 on one line and 2cosΘ=-1 on the next !
    Being meticulous while learning this pays off all through the rest of your life (and that of possible pupils/students you might have later on :smile:)
    By the way, welcome to PF !
Have something to add?
Draft saved Draft deleted
