Hurricane-like storm on Saturn
In summary, NASA's Cassini spacecraft has seen something never before seen on another planet -- a hurricane-like storm at Saturn's South Pole with a well-developed eye, ringed by towering clouds. The "hurricane" spans a dark area inside a thick, brighter ring of clouds. It is approximately 5,000 miles across, or two thirds the diameter of Earth.
Astronomy news on Phys.org
Fascinating! The eye is very similar indeed!
RELEASE: 06-344 - NASA Sees Into the Eye of a Monster Storm on Saturn
"It looks like a hurricane, but it doesn't behave like a hurricane," said Andrew Ingersoll, a member of Cassini's imaging team at the California Institute of Technology, Pasadena. "Whatever it is, we're going to focus on the eye of this storm and find out why it's there."
A movie taken by Cassini's camera over a three-hour period reveals winds around Saturn's South Pole blowing clockwise at 350 miles per hour. The camera also saw the shadow cast by a ring of towering clouds surrounding the pole, and two spiral arms of clouds extending from the central ring. These ring clouds, 20 to 45 miles above those in the center of the storm, are two to five times taller than the clouds of thunderstorms and hurricanes on Earth.
Eye-wall clouds are a distinguishing feature of hurricanes on Earth. They form where moist air flows inward across the ocean's surface, rising vertically and releasing a heavy rain around an interior circle of descending air that is the eye of the storm itself. Though it is uncertain whether such moist convection is driving Saturn's storm, the dark "eye" at the pole, the eye-wall clouds and the spiral arms together indicate a hurricane-like system.
Distinctive eye-wall clouds have not been seen on any planet other than Earth. Even Jupiter's Great Red Spot, much larger than Saturn's polar storm, has no eye or eye-wall, and is relatively calm at the center.
This giant Saturnian storm is apparently different than hurricanes on Earth because it is locked to the pole and does not drift around like terrestrial hurricanes. Also, since Saturn is a gaseous planet, the storm forms without an ocean at its base.
In the Cassini imagery the eye looks dark at light wavelengths where methane gas absorbs the light and only the highest clouds are visible.
"The clear skies over the eye appear to extend down to a level about twice as deep as the usual cloud level observed on Saturn," said Kevin H. Baines, of Cassini's visual and infrared mapping spectrometer team at NASA's Jet Propulsion Laboratory, Pasadena, Calif. "This gives us the deepest view yet into Saturn over a wide range of wavelengths, and reveals a mysterious set of dark clouds at the bottom of the eye."
Infrared images taken by the Keck I telescope in Mauna Kea, Hawaii, had previously shown Saturn's South Pole to be warm. Cassini's composite infrared spectrometer has confirmed this with higher resolution temperature maps of the area. The spectrometer observed a temperature increase of about 4 degrees Fahrenheit at the pole. The instrument measured high temperatures in the upper troposphere and stratosphere, regions higher in the atmosphere than the clouds seen by the Cassini imaging instruments.
"The winds decrease with height, and the atmosphere is sinking, compressing and heating over the South Pole," said Richard Achterberg, a member of Cassini's composite infrared spectrometer team at NASA's Goddard Spaceflight Center, Greenbelt, Md.
Observations taken over the next few years, as the South Pole season changes from summer to fall, will help scientists understand the role seasons play in driving the dramatic meteorology at the south pole of Saturn.
The "hurricane" spans a dark area inside a thick, brighter ring of clouds. It is approximately 8,000 kilometers (5,000 miles) across, or two thirds the diameter of Earth.
http://www.nasa.gov/mission_pages/cassini/media/cassini-20061109.html
I have to wonder about the statement that "since Saturn is a gaseous planet, the storm forms without an ocean at its base". I don't think this is necessarily correct. Given the pressures and temperatures, at some point there has to be liquid. We just need to take a closer look! :-p :approve: I would like to see probes dropped down to the 'surface' of both Saturn and Jupiter to explore the conditions down in the atmosphere.
Absolutely right. At some pressure, those gases must be liquid, and it's hard to imagine that the latent heat of vaporization doesn't contribute to driving convection in the gaseous phase, including that monster storm.
Related to Hurricane-like storm on Saturn
1. What causes a hurricane-like storm on Saturn?
The exact cause of these storms is still unknown, but it is believed to be a result of the planet's strong winds and jet streams, as well as its unique atmospheric conditions.
2. How long can a hurricane-like storm last on Saturn?
The duration of these storms can vary, but they have been observed to last for months or even years. The Great White Spot storm, which occurred in 2010, lasted for approximately seven months.
3. Is the hurricane-like storm on Saturn similar to hurricanes on Earth?
While both are large, rotating storms, the hurricanes on Earth are mainly fueled by warm ocean waters, while the storm on Saturn is fueled by atmospheric conditions. Additionally, the size and strength of the storms on Saturn are much larger than those on Earth.
4. How do scientists study and monitor the hurricane-like storm on Saturn?
Scientists use a variety of instruments and spacecraft, such as the Cassini orbiter, to study and monitor the storm on Saturn. They also use computer models and simulations to better understand its behavior and predict its movements.
5. Can the hurricane-like storm on Saturn affect the planet's rings?
There is evidence that the strong winds and turbulence created by the storm can affect the planet's rings. The Great White Spot storm, for example, caused changes in the rings' appearance and structure. However, the exact extent of the impact is still being studied by scientists.
  • Astronomy and Astrophysics
