Huygens Office Pool Bets: Friday's Options
  • Thread starter DaveC426913
  • Tags
    Huygens
In summary, Huygens has landed on the surface of Titan and first data should be received this afternoon. It is a moon at the right distance from Saturn for life to form, but there is a chance of nearby liquid. Equipment failure is always a good bet, but fortunately it did not happen in this case.
  • #71
Are you sure? 56k, isn't that 56,000 bits per second?
Astronomy news on Phys.org
  • #72
According to http://www.planetary.org/sounds/huygens.html says they're able to get a much higher bandwidth from the Mars rovers:
Engineers on the $820 million mission increased the rover Spirit's maximum data rate to 256,000 bits per second, using NASA's 2001 Mars Odyssey orbiter as a martian relay satellite.
  • #73
http://www.esa.int/esaCP/SEMHB881Y3E_index_0.html
"The first scientific assessments of Huygens' data were presented during a press conference at ESA head office in Paris on 21 January."
"Geological evidence for precipitation, erosion, mechanical abrasion and other fluvial activity says that the physical processes shaping Titan are much the same as those shaping Earth."
"Images have shown a complex network of narrow drainage channels running from brighter highlands to lower, flatter, dark regions. These channels merge into river systems running into lakebeds featuring offshore 'islands' and 'shoals' remarkably similar to those on Earth"
"In addition, DISR surface images show small rounded pebbles in a dry riverbed. Spectra measurements (colour) are consistent with a composition of dirty water ice rather than silicate rocks."
"Huygens' data provide strong evidence for liquids flowing on Titan. However, the fluid involved is methane"
"Titan's rivers and lakes appear dry at the moment, but rain may have occurred not long ago."
So, no recommendable to go fishing to those rivers...if you don't like the taste of methane :yuck:
  • #74
Titan Titration...
Saturn's largest moon apparently is lashed regularly by rain made of liquid methane, forming pools, cutting river beds and eroding rocks in much the same way that forces have shaped the Earth
Black-and-white photos from the Huygens probe show a rugged terrain of ridges, peaks, dark vein-like channels and apparently dry lakebeds on the moon 744 million miles away.
On Earth, methane is a flammable gas. On Titan, it is a liquid because of the intense pressure and cold -- 274 degrees below zero.
A sensor about the size of a police officer's nightstick on the front of Huygens probed beneath the moon's crust and found a material with the consistency of loose sand.
Channels on the surface are evidence of methane rain. There are also what appear to be river systems and deltas, frozen protrusions riddled by channels, apparent dried-out pools where liquid has perhaps drained away, and stones -- probably ice pebbles -- that seem to have been rounded by erosion.
The river beds are darkened by what seem to be particles of smog that fall out of Titan's atmosphere, coating the terrain. The dirt apparently gets washed off the ridges by the methane rain to collect in the river channels.
Scientists believe the dark smog particles are formed by Titan's methane breaking up in the atmosphere.
Lebreton, the mission manager, said a next possible step in Titan exploration would be to send mobile probes, perhaps balloons to float around before landing.
Reference:
http://www.harktheherald.com/modules.php?op=modload&name=News&file=article&sid=45812&mode=thread&order=0&thold=0
  • Mechanical Engineering
  • Astronomy and Astrophysics
  • General Discussion
10K
  • Mechanics
