wolram
Dearly Missed
- 4,446
- 558
Imagine a bar, say 3inches dia by 15inches long, the bar is turned down to
1inch dia 3inches in for 3inches, and again at 9 inches for three inches, this
forms 3, connected (pistons), this piston assembly is enclosed in a cylinder
the outer pistons are moved by internal combustion using the 2 stroke principle,
the inner piston is used as a hydrulic pump, when say the right cylinder fires, a valve opens
on the left of the centeral pump piston, and the reverse as the left cylinder fires, the hydraulic pressure is such that it will not allow the ic pistons to (bottom out), thus forming
a hydraulic motor with only one moving part, will it work.
Second draft as first was nonsence.
