• Support PF! Buy your school textbooks, materials and every day products Here!
Hydraulic lift
  • Thread starter Mowgli
In a hydraulic lift the radii of the pistons are 1.75cm and 10.5cm. A car weighing 18.5kN is to be lifted by the force of the large piston.
a.) what force must be applied to the small piston?
b.) when the small piston is pushed 1.00cm, how far is the car lifted?
c.) find the mechanical advantage of the lift (this is the ratio of the large force to the small force)
a.) F= (r/R)^2 (F)
= (1.75 cm/10.5 cm)^2 (18.5 kN)
= .514 or 514 N
b.) Win(f)= Wout(F)= fh=FH=H= (f/F)h= (pi)r^2/(piR^2=(r/R)^2
= (1m/R)^2 = (100cm/10.5cm)^2
= 90.7cm
c.) MA= F/f= 18.5kN/1.75cm
= 10.57
I have no clue if I am doing this right.. can anyone help?
Answers and Replies
Doc Al
Mentor
44,867
1,114
a.) F= (r/R)^2 (F)
= (1.25 cm/15.0 cm)^2 (14.5 kN)
= .1007 or .101 N
Good, but careful with units. (Those are kN, not N.)
= 90.7cm
FH = fh is correct. What's the ratio of the forces?
= 10.57
I'm not sure how to find that?
Doc Al
Mentor
44,867
1,114
Use what you found in part a.
is it 1/10?
Doc Al
Mentor
44,867
1,114
is it 1/10?
Nope. You were given one force and for part a you found the other force. What's their ratio?
I just realized my problem had the wrong numbers- so I edited the problem...
For part b.) is my ratio now 18.5/514????
(18.5/514)^2 ??
and then I think c.) is MA=F/f = 18.5/.514
= 35.9
Can anyone help?
Trying to figure this out:
b.) (r/R)^2
so, therefore it should be (1.75/10.5)^2
which = .0278
c.) MA= F/f = 18.5/.514 = 35.9
Doc Al
Mentor
44,867
1,114
b.) (r/R)^2
which = .0278
That's fine. The ratio of forces is given by (R/r)^2 = (10.5/1.75)^2 = 6^2 = 36.
So for b, the large piston will raise by 1/36 of the distance the small piston is lowered.
And for c, the mechanical advantage is just that ratio of forces.
Related Threads for: Hydraulic lift
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
