Hydraulic Lift
  • Thread starter BeiW
A hydraulic lift is used to jack a 970 kg car .12m off the floor. The diameter of the output piston is .18 m, and the input force is 270 N.
If the input piston moves .13 m in each stroke, how high does the car move up for each stroke?
2-3. Relevant equations and attempt at solving
Fin=Fout
That becomes pghA=pghA
p = density
g=gravity
h=height
A=area
So I get 270=p(9.8)(.13)(A) which is the input force.
I could set that equal to the output force:
270=p(9.8)(.13)(A1)=(p)(9.8)(h2)(.02545)
.02545 is the area of a circle when I plug in .09 for radius.
The p's would cancel, and I'm left with the variables A1 and h2.
I know I can use the system of equations to solve this, but I want to know if I set up the equations correctly. And also, what do I do with the .12 m (that the car is lifted off the ground)??
Answers and Replies
i believe the .12m is given so that you can find the initial height of the input piston since they are not in equilibrium
In that case, would I add the .12m to the .13 for h1?
.12m refers to the car or height of the output piston, the input piston moves by .13m, the distance the car moves is related by the force/piston area ratios of the input and output
Related Threads on Hydraulic Lift
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
