Hydraulic press brake ?
  • Thread starter JMTC
Main Question or Discussion Point
Hi all, I am designing a Hydraulic press brake to air bend up to 4 feet of 1/8 in mild steel.
I know it will take 11 tons of force per foot of material, 44 ton to do the trick.
A 60 ton jack will cost over $1000, where 3-20 ton jacks are $40 each.
My question, if I evenly space the 3 20 ton jacks along the 4 foot length & connect them so they all jack at the same time, will there be 60 ton of force applied to the work.
I have been searching for days, then came across this site which answered my question but not with enough certainty for me to proceed with the project.
Thanks in advance
Answers and Replies
Im going to buy the material today, I guess I'll just have to hope it works.
... My question, if I evenly space the 3 20 ton jacks along the 4 foot length & connect them so they all jack at the same time, will there be 60 ton of force applied to the work. ...
In the simplest terms, possibly. There are myriad variables in play.
IMHO, you're going to have problems keeping three independent jacks at equal pressure during the bend. You may need to bottom-bend to get a consistent result. (Bottom-bending also requires much greater tonnage.)
Thanks for the input pantaz, I decided to hold off & re-think this project, I have been estimating material size thickness for the "H" frame of the press, "I" beam I planned on using is likley not up to the job either. With all the time & money involved failure is not an option.
Jim
Related Threads on Hydraulic press brake ?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
