Hydraulic Pump/Motor: Can it Work as a Motor?
  • Thread starter 1nv3n73r
  • Tags
    Hydraulic
In summary, a hydraulic pump can be used as a hydraulic motor if it is backdriven and designed for bi-directional operation.
1nv3n73r
hey people. literally just joined, hehehe
my question is, can a hydraulic pump be used as a hydraulic motor. i have an idea and want to have it operating using hydraulics rather than having shafts and gearboxes to transfere to work.
any comments welcome, good or bad, but i prefere good...hehehe
From Wikipedia:
Conceptually, a hydraulic motor should be interchangeable with a hydraulic pump because it performs the opposite function - similar to the way a DC electric motor is theoretically interchangeable with a DC electrical generator. However, most hydraulic pumps cannot be used as hydraulic motors because they cannot be backdriven. Also, a hydraulic motor is usually designed for working pressure at both sides of the motor.
Thanks Jack action.
There is information there that I didn't know about.
What you are describing is a hydro-static transmission. The pump and motor can each be designed to be pump/motors, but they aren't necessarily that way, as jack action said.
Conceptually simple, but there are many traps for the beginner. Pumps will often have a big inlet because only atmospheric pressure is available to push oil into the pump chamber, it can have a smaller outlet.
Pumps are usually designed to rotate in one particular direction. A hydraulic pump is designed to have a low and a high pressure side with seals to prevent it sucking air on the inlet side or weeping oil on the high pressure side.
A hydraulic motor may be designed for bi-directional operation. It can be operated with positive pressure on both ports. Bidirectional motors will have a third connection to drain fluid to the reservoir tank that leaks past the internal seals.
Hydraulic motors and pumps might get to 90% efficiency. A pump driving a motor will therefore have 90% * 90% = 81% efficiency. You will need to pay for that 19% inefficiency, you will also need an oil cooler to remove the 19% waste heat. A manual change gearbox will be closer to 98% efficient.
1. How does a hydraulic pump/motor work as a motor?
A hydraulic pump/motor works by converting hydraulic energy into mechanical energy. This is achieved through the use of a rotating shaft that is powered by pressurized fluid. The pressurized fluid causes the shaft to rotate, which in turn drives a load.
2. What is the difference between a hydraulic pump and a hydraulic motor?
A hydraulic pump is used to convert mechanical energy into hydraulic energy, while a hydraulic motor converts hydraulic energy into mechanical energy. In other words, a pump is used to generate fluid pressure, while a motor uses that fluid pressure to produce motion.
3. Can a hydraulic pump/motor be used in both directions?
Yes, a hydraulic pump/motor can be used in both directions. This is because it utilizes the same principles of converting energy, regardless of the direction of motion. However, the efficiency of the pump/motor may vary depending on the direction it is being used.
4. What are the advantages of using a hydraulic pump/motor as a motor?
One advantage is that it can provide high torque at low speeds, making it ideal for heavy-duty applications. It is also highly efficient, with minimal energy loss. Additionally, it can be controlled easily and precisely, making it suitable for a wide range of industrial and commercial applications.
5. Are there any limitations to using a hydraulic pump/motor as a motor?
One limitation is that it requires a constant supply of pressurized fluid, which can be costly and may limit its use in certain environments. Additionally, it may produce noise and vibrations, which can be a disadvantage in some applications. Finally, it may require regular maintenance to ensure optimal performance.
  • Mechanical Engineering
