1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Hydrodynamic calculations
  1. Feb 2, 2014 #1
    Hi all,
    This is my first post. I was wondering what the effects of hydrodynamics are on water in regards to when you suck water out of a pipe leading to a barrel of water for example. When you then stop sucking the water from the pipe the water leaving the pipe then continues to pull water out of the barrel until the barrel is fully drained.
    Firstly what is this effect correctly called? Is this more to do with pressure differential?
    Secondly, what are the limitations of this effect? I mean the diameter of the pipe, the original container needs to be higher than the receiving container etc?
    This is an interesting phenomenon to me and I would like to learn more about it and hope that you may be able to educate me in this regards or to steer me in the right direction. Finally how would I calculate the velocity of the water leaving the pipe and other similar calculations relating to this effect. Thanks in advance for your assistance.
    Kind regards,
  3. Feb 2, 2014 #2
    Staff Emeritus
    I think you are describing a siphon, but you description is not totally clear to me. The siphon effect works on a difference in pressures between two bodies of liquid.
  4. Feb 2, 2014 #3
    Wow, that's exactly what I was looking for SteamKing. Thanks!
  5. Feb 2, 2014 #4
    Staff Emeritus
    You're welcome.
Similar Threads - Hydrodynamic calculations Date
I Calculating water pressure and the required mass of water Today at 3:53 AM
B Hydrodynamic Levitation Jun 27, 2017
A Terminal Velocity of a Cylinder Freefalling Through a Fluid May 12, 2016
Sinking Vehicle Apr 11, 2015
Aerodynamic/hydrodynamic drop pod Aug 28, 2012
