Hydrostatics (abs pressure)
  1. Jan 4, 2014 #1
    (a) Calculate the absolute pressure at the bottom of a fresh-water lake at a depth of 22.5 m. Assume the density of the water is 1.00x10^3 kg/m3 and the air above is at a pressure of 101.3 kPa.
    (b) What force is exerted by the water on the window of an underwater vehicle at this depth if the window is circular and has a diameter of 33.6 cm?
    2. Relevant equations
    P(abs pressure)= ρgh+P(atmospheric pressure)
    3. The attempt at a solution
    (1000)(9.81)(22.5)+101.3 = 322.025 kPa
    I don't understand what I'm doing wrong my webassign says I'm off by a multiple of 10 and I cant do part b without getting part a right :(
  3. Jan 4, 2014 #2
    This result looks OK to me. 22.5 m of water is on the order of about 60 - 70 ft of water, which is about 2 atm. So your answer, which is a little over 3 atm sounds correct.
  4. Jan 4, 2014 #3
    but then why are my calculations wrong according to my webassign answer key :confused:
  5. Jan 4, 2014 #4
    haruspex
    You do have an error in the working as posted - a factor of 1000 which should have been cancelled in converting from Pa to kPa. But as Chet wrote your answer is correct.
    When you say the web answer is different by a factor of 10, do you know what that answer is? Is it exactly a factor of 10, or maybe 2308.6 or 123.4? And can you proceed to part b by putting in the web answer?
  6. Jan 4, 2014 #5
    I do not know the correct answer, I only have 5 tries and this is my last try to get it right :frown: and I can proceed to part b whenever I want but for it to be right I need to have the exact right answer for part a so it would help a ton if you could help point out the exact answer which I missed because I still don't quite understand where exactly I went wrong :(
  7. Jan 4, 2014 #6
    Well, here are some possibilities:
    1. The answer in webassign is wrong
    2. Webassign is looking for the answer in Pa, not kPa
    3. Webassign is looking for the answer in atm.
    I'm guessing #1.
    Chet
  8. Jan 4, 2014 #7
    I actually tried putting it in Pa instead and I got it right thank you so much for the tip! :)
Have something to add?
Draft saved Draft deleted
Similar Discussions: Hydrostatics (abs pressure)
  1. Hydrostatic Pressure? (Replies: 1)
  2. Hydrostatic Pressure (Replies: 1)
  3. Hydrostatic pressure (Replies: 2)
Loading...
