Hyperbolic Triangles: Deriving Relationships Algebraically or Geometrically
In summary, the two functions are essentially similar, but the cosine has a "tail" on the negative side.
electricspit
66
Hello, I'm going through Landau and Lifshitz "The Classical Theory of Fields" this summer with a friend and in section 4 I've come to a bit of a math problem.
Assume you have an inertial frame [itex]K'[/itex] moving at speed [itex]V[/itex] relative to an inertial frame [itex]K[/itex] in the [itex]x[/itex]-direction. In order for invariant intervals we require:
[itex]
(ct)^2 - x^2 = (ct')^2 - (x')^2
[/itex]
For this to be true:
[itex]
x = x'\cosh{\Psi}+ct'\sinh{\Psi}
[/itex]
[itex]
ct=x'\sinh{\Psi}+ct'\cosh{\Psi}
[/itex]
Where [itex]\Psi[/itex] is the angle of rotation in the [itex]xt[/itex] plane. Which makes sense. Now if we just look at the origin of the [itex]K'[/itex] frame moving these can be reduced to:
[itex]
x=ct'\sinh{\Psi}
[/itex]
[itex]
ct=ct'\cosh{\Psi}
[/itex]
and dividing the equations yields:
[itex]
\tanh{\Psi}=\frac{x}{ct}
[/itex]
But the speed [itex]V[/itex] is given by [itex]V=\frac{x}{t}[/itex] so:
[itex]
\tanh{\Psi}=\frac{V}{c}
[/itex]
The next part is what is a bit confusing. If this were regular trigonometry to find both [itex]\sin{\Psi}[/itex] and [itex]\cos{\Psi}[/itex] would just require the construction of a triangle. In this case however, they end up with very, very similar results except where the hypoteneuse would be they end up with something like this:
[itex]
\sinh{\Psi}=\frac{\frac{V}{c}}{\sqrt{1-({\frac{V}{c}})^2}}
[/itex]
[itex]
\cosh{\Psi}=\frac{1}{\sqrt{1-({\frac{V}{c}})^2}}
[/itex]
If anyone can point me in the right direction of deriving these relationships either algebraically or using geometry that would be extremely helpful!
[itex]
[/itex]
[itex]
[/itex]
[itex]
[/itex]
[itex]
x=ct'\sinh{\Psi}
[/itex]
[itex]
ct=ct'\cosh{\Psi}
[/itex]
[itex]
[/itex]
[itex]
[/itex]
[itex]
\sinh{\Psi}=\frac{\frac{V}{c}}{\sqrt{1-{\frac{V}{c}}^2}}
[/itex]
[itex]
\cosh{\Psi}=\frac{1}{\sqrt{1-{\frac{V}{c}}^2}}
[/itex]
[tex]\sinh{\Psi}=\frac{\tanh{\Psi}}{\sqrt{1-\tanh^2{\Psi}}}[/tex]
[tex]\cosh{\Psi}=\frac{1}{\sqrt{1-\tanh^2{\Psi}}}[/tex]
Okay hmm, assuming the Wikipedia section on "Comparison with circular functions" is correct then this is what I make of it all:
http://imgur.com/4eL9du1
Sorry for the mess, I've been working all day and am too tired to be perfect.
Hello there! I would like to provide a response to the content you have shared about hyperbolic triangles and deriving relationships algebraically or geometrically. First of all, I must commend you for taking on the challenge of studying Landau and Lifshitz's "The Classical Theory of Fields" this summer. It is a complex and advanced topic, and I am glad that you are seeking help when you encounter difficulties.
Now, let's address the specific problem you have mentioned. It seems like you are trying to understand the relationships between the x, ct, and ct' coordinates in the K and K' frames, and how they relate to the speed V. This is indeed a tricky problem, but it can be solved using both algebraic and geometric methods.
First, let's look at the algebraic approach. You have correctly derived the equations x = x'\cosh{\Psi}+ct'\sinh{\Psi} and ct=x'\sinh{\Psi}+ct'\cosh{\Psi}. These equations relate the x, ct, and ct' coordinates in the two frames using the angle of rotation \Psi. Now, if we rearrange these equations, we can obtain:
x' = (x-ct\tanh{\Psi})/\cosh{\Psi} and ct' = (ct-x\tanh{\Psi})/\sinh{\Psi}
Substituting these into the invariant interval equation (ct)^2 - x^2 = (ct')^2 - (x')^2, we get:
(ct)^2 - x^2 = \frac{(ct-x\tanh{\Psi})^2}{\sinh^2{\Psi}} - \frac{(x-ct\tanh{\Psi})^2}{\cosh^2{\Psi}}
Simplifying this equation, we get:
(ct)^2 - x^2 = (ct)^2 - x^2
This shows that the invariant interval is indeed preserved, as it should be. Now, to find the relationships between \sinh{\Psi} and \cosh{\Psi}, we can use the definitions of hyperbolic sine and cosine functions:
\sinh{\Psi} = \frac{e^{\Psi} - e^{-\Psi}}{2} and \cosh{\Psi} = \frac{e^{\Psi} + e^{-\Psi}}{2}
Using these definitions, we can obtain the expressions
1. What is a hyperbolic triangle?
A hyperbolic triangle is a triangle that is formed on a hyperbolic surface, which is a surface with a constant negative curvature. This is in contrast to a Euclidean triangle, which is formed on a flat surface with zero curvature.
2. How do you derive relationships algebraically between hyperbolic triangles?
To derive relationships algebraically between hyperbolic triangles, you can use the hyperbolic trigonometric functions such as hyperbolic sine, cosine, and tangent. These functions are defined in terms of the hyperbolic exponential function and can be used to solve for unknown sides and angles in a hyperbolic triangle.
3. What is the difference between deriving relationships algebraically and geometrically?
Deriving relationships algebraically involves using equations and mathematical operations to solve for unknown sides and angles. This is a more abstract and theoretical approach. Geometrically, relationships can be derived by using the properties and constructions of hyperbolic triangles on a hyperbolic surface, which is a more visual and concrete approach.
4. Can you use the same formulas for hyperbolic and Euclidean triangles?
No, the formulas for hyperbolic triangles are different from those for Euclidean triangles. This is because the properties and measurements of hyperbolic triangles are affected by the negative curvature of the surface they are formed on, which is not the case for Euclidean triangles on a flat surface.
5. How are hyperbolic triangles used in real-world applications?
Hyperbolic triangles have applications in fields such as astronomy, physics, and geometry. For example, they are used in celestial navigation to calculate distances and angles in space. They also have applications in computer graphics and 3D modeling, as well as in the study of non-Euclidean geometries.
