Hypergeometric D.E.
  1. Oct 18, 2008 #1
    The Heun equation is a generalization of the hypergeometric D.E. to the case
    of four regular singular points. With the singular points at z=0,1,a,and inft,
    the Heun equation takes the form,
    (a) In terms of k_1, k_2, k_3, k_4 and a, calculate c_1, c_2, c_3, c_4 and e,
    such that the Riemann P-function for this Heun equation is
    w=P( 0 a 1 inft )
    ( 0 0 0 k_1 z)
    ( 1-k_3 1-k_4 1-e k_2 )
    (b) In the special case when k_4=0 and the general solution is free of
    logarithms at z=a, show that the Heun equation reduces to a hypergeometric
    equation. Give the general solution in terms of hypergeometric functions.
    (c) Obtain a quadratic equation for the accessory parameter c_5 in the
    special case when k_4=-1 and the general solution is free of logarithms at
    z=a. (In this case, z=a is an apparent singularity of the differential equation)
    2. Relevant equations
    Um i guess the indicial equation to find the exponents at the regular singular points. What i wasn't sure about was that from the equations, i found that k_1+k_2+k_3+k_4+e=1 necessarily.
    3. The attempt at a solution
    I've done part (a) using indicial equations to find exponents, and then equate.
    Part B: From part a, i got using indicial equations that k_4=0 implies that c_1*a^2+c_2*a+c_3=0, so c_1*z^2+c_2*z+c_3 = c_1*(z-a)*(z-a') for some number a'. Then in the equation, if c_4*z+c_5 has a as a factor, i.e. c_5=-a*c_4, then we can divide through by z-a and get a hypergeometric D.E. So i need to prove that if the general solution is free of logarithms, then c_5=-a*c_4; i'm not quite sure how to do it rigorously. I tried doing it by using a power series about z=a, and proved that we reach a contradiction if there are no terms of negative power (i.e. (z-a)^(-t)) in the Laurent series, but I'm not sure how to justify that.
    for part (c ), i'm clueless.
Draft saved Draft deleted
