Hysteresis loop in maxwell
  • Thread starter pedro1988
Main Question or Discussion Point
hi my dear friends
i face with a problem in ansoft maxwell;
i want to import a hysteresis material's loop into maxwell's material s libraray
but i cant!:(
is there anyone who can help me?
with the best wishes:)
pedro
Answers and Replies
gerbi
In material library click "add material". Now you can define parameters of your new material. Select "nonlinear" instead of "simple" for relative permeability and then left-click on newly appeared button "B-H curve". Add B-H points defining curve here.
Another approach (when you need to define B-H loops in all 3 directions x,y,z) is to select "anisotropic" instead of "nonlinear" in first step. Then you can select "nonlinear" for every axis (and three separate B-H curves).
One more thing. This feature has evolved in maxwell, so it may not be avaible in your version for some solvers or may be working a little differently (I am using v.16.0.0).
i use v16.0.0
AND i do what you say
but its not accept a b-h curve points and says "
http://s1.uploads.im/BUlWJ.jpg [Broken]
THANKS A LOT
gerbi
Hmm.. you want to input full B-H curve ? No chance. Use only one quarter of characteristic (+ H / + B) and average values (maxwell will accept only single B-H curve).
realy??!!
no way to import full b-h curve?
so how a motor can be designed with hysteresis material.....:(:(
its too bad
thank you for cooperation
gerbi
It can be done with average values (single curve for +H/+B). Thats how it's done in most cases.
Likes 1 person
Most magnetostatic simulators solve linear material models only. Yes, it sucks but you can do surprisingly well by using a linear simulation and simply watching out for fields that approach within 80% of the saturation field. The simulations for linear are radically faster than those that include hysteresis (which is both nonlinear AND time-dependent).
Likes 1 person
Related Threads on Hysteresis loop in maxwell
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
