I can't figure out springs in Python
  1. Oct 16, 2011 #1
    For the following Python program, I have to alter the block.Fspring to create realistic spring force, but I can't figure out how to do so. I know the spring force is -k(mag(block.pos - support.pos) - L0), but I don't know how to alter that to apply direction. Please help! I figured I'd use the dot product of that and the parallel unit vector, but it doesn't work...
    from visual import *
    from visual.graph import * # Loads in graphing module
    scene.y = 400 # Moves the visual window down
    #Constants
    g = 9.8 #m/s^2
    m = 10 #kg Mass of a box
    muk = 0.05 # Coefficient of kinetic friction
    k = 150 #N/m Spring constant
    dt = 0.01 #s Time step
    lrate = 500 # Loops per second
    zero = vector(0,0,0)
    angle = 100
    while angle < 0 or angle > 90:
    angle = input("Enter the angle of incline in degrees: ")
    theta = radians(angle) # Converts the angle from degrees to radians
    npar = vector(cos(theta), sin(theta), 0) #unit vector parallel to incline
    nperp = vector(-sin(theta), cos(theta), 0) #unit vector perpendicular to incline
    blocksize = 0.4 #m size of cubic box
    Lincline = 2 #m length of incline
    Wincline = 2*blocksize # width of incline
    Hincline = 0.1 #m height of incline
    #The two lines below calculate the initial position of the block and spring support
    blockpos = (Lincline-blocksize)/2*npar + (blocksize+Hincline)/2*nperp
    supportpos = -(Lincline-Hincline)/2*npar + (Hincline+blocksize)/2*nperp
    print "\nThe block is starting at position ", blockpos, "m."
    #Objects
    incline = box(length=Lincline, width=Wincline, height=Hincline,
    axis = npar, color=color.blue)
    block=box(pos = blockpos, length=blocksize, width=blocksize, height=blocksize,
    axis = npar, color=color.green)
    support = box(pos=supportpos, length=Hincline, width=Wincline, height=blocksize,
    axis = npar, color=color.red)
    spring = helix(pos=support.pos, axis = block.pos - support.pos, radius=Hincline,
    thickness=Hincline/10, color=color.yellow)
    # The lines below set up graphs
    graph1 = gdisplay(x=0,y=0,width=400,
    xtitle='time (s)',ytitle='x (m)')
    graph2 = gdisplay(x=400,y=0,width=400,
    xtitle='time (s)',ytitle='y (m)')
    graph3 = gdisplay(x=800,y=0,width=400,
    xtitle='time (s)',ytitle='v (m/s)')
    xgraph=gcurve(gdisplay=graph1,color=color.yellow)
    ygraph=gcurve(gdisplay=graph2,color=color.green)
    vgraph=gcurve(gdisplay=graph3,color=color.red)
    #Initial values
    L0 = mag(block.pos - support.pos) #equilibrium length of spring
    block.v = zero #Block is initially at rest
    block.Fgrav = vector(0,-g,0)
    block.N = - dot(block.Fgrav, nperp)*nperp
    block.Fgravpar = dot(block.Fgrav, npar)*npar
    t = 0
    #Loop through repetitive calculations
    # A while loop repeats until the statement becomes false
    while t < 10: #Loop for 10 seconds
    rate(lrate) #Slows down the animation(smaller lrate, slower animation)
    # Modify the lines below to the correct expressions.
    block.Fspring = -k*mag(block.pos - support.pos)*L0
    block.Fk = zero
    block.Fnet = block.Fgrav + block.N + block.Fspring + block.Fk
    block.a = block.Fnet
    block.v = block.v + block.a*dt
    block.pos = block.pos + block.v*dt
    spring.axis = block.pos-support.pos #Updates the spring
    t = t + dt #Updates the time
    # The lines below graph the following:
    # x pos vs time
    # y pos vs time
    # magnitude of velocity vs time
    xgraph.plot(pos=(t, block.pos.x))
    ygraph.plot(pos=(t, block.pos.y))
    vgraph.plot(pos=(t, mag(block.v)))
    #Printing results
    # Unindenting the lines means that the following statements are
    # executed AFTER the loop ends
    print "The final position is", block.pos, "m."
Draft saved Draft deleted
