Tosh5457
- 134
- 28
I've read the article in wikipedia but I can't understand it. Can someone point me to a good explanation of what a Q-Q plot shows and how to make one, or explain to me please?
Tosh5457 said:I've read the article in wikipedia but I can't understand it. Can someone point me to a good explanation of what a Q-Q plot shows and how to make one, or explain to me please?
A Q-Q plot, short for quantile-quantile plot, is a graphical tool used to compare the distribution of two datasets. It plots the quantiles of one dataset against the quantiles of another dataset, allowing for visual assessment of how similar or different their distributions are.
The closer the points on a Q-Q plot are to the diagonal line, the more similar the distributions of the two datasets are. If the points fall along the diagonal line, it indicates that the two datasets have the same distribution. Deviations from the diagonal line suggest differences in the shape, spread, or location of the distributions.
A skewed Q-Q plot indicates that the two datasets being compared have different distributions. This means that the data may not follow a normal distribution and may require different statistical methods for analysis.
To create a Q-Q plot, you first need to have two datasets with numerical values. Then, you can use a statistical software or programming language to plot the quantiles of one dataset against the quantiles of the other dataset. Alternatively, you can create a Q-Q plot by hand using graph paper and calculating the quantiles manually.
No, a Q-Q plot is specifically designed for comparing the distributions of numerical data. It cannot be used for non-numerical data, such as categorical or ordinal data. In these cases, other graphical or statistical methods should be used to compare the distributions.
