Exploring the Convergence of 0.999... and the Concept of Infinity
  • Thread starter ram2048
In summary: Also, if you're so caught up in your own theory that you can't see the flaws in it, you might want to reevaluate your perspective.
  • #281
ram2048 said:
i made the comparison that .999~ was infinite un ending number of 9's just like in the case with your apples. you never replied back when i said that if they're infinite un-ending i should be able to eat an infinite amount of them without affecting that property. such that:
.999~ - .999~ = .999~ (unending) (minus) (infinite) (equals) (unending)
please verify.
Did you read my last post well? It seems you didn't, i explained you that .999... is a REAL NUMBER so .999... - .999... = 0
Re-read well my last post since you did not understand it in depth.
.999... is infinite?
i explained the number of digits thing in the last post
eating apples non-endingly from a non-ending supply of apples
can only be represented as infinite - infinite which is undeterminate
you cannot say that it is equivalent to .999... - .999...
and when i talked about the apples i meant to tell you that you can take a finite number of apples of a non-ending supply but there will always be a non-ending supply of apples.
This was to show you the true nature of infinite.
I think you should have understood it by now.
  • #282
i would count to infinity (magnitude).
But never arrive at infinity.
  • #283
hello3719
I don't see a problem. When I write ~ or ... or _ we mean that the pattern repeats itself never-endingly
.999~ - .999~ = indeterminate then?
oh apples can't be 9's? why can't they be. numbers are just tools for describing reality. if i substitute an apple for every 9 there's no failure in logic, just the contradiction you happily supplied
  • #284
Integral: you don't want to read about it then you're free to leave and never look back.
fact of the matter is you're so scared i might be right that you're unwilling to apply any effort at all to understand me.
my "system" irons out a lot of kinks in the current system and replaces a lot of false notions and assumptions with perfect logical ones.
you wouldn't lash out like this if you weren't feeling threatened by me.
  • #285
true enough
  • #286
ram, when we say there are an infinite number of nines in the expansion 0.999... we mean exactly what the word literally means: that the number of them is not finite. that is all. we also can go further and say they are in bijection with N, tha natural numbers, by place.
we are not using infinity as a number in the same sense as a real number. that is why we have cardinals, and ordinals, which are dsitinct, and have different arithmetics. there are also infinitesimals. we also have analysis.
so you have developed a symbol, call ik K, that indicates the 'number' of 9s in the expression 0.99999...
how many elements are there in N or Z? how many finite groups are there?
seems like you're going to have to have a different one for every object unless you give a way of comparing them. is there a comparison?
  • #287
What is it that I should fear? You have not presented a single coherent concept. you have repeatably demonstrated your lack of knowledge or understanding of mathematics. you simply do not have the tools to formulate a meaningful mathematical statement. Your ideas are not to be feared they are to be laughed at.
Before you can even think about fixing something you must understand how it works. You do not understand the Real Number system, therefore have no hope of "fixing" it.
lets do a bit of simple arithmetic.
.999... - .999... =
[tex]( \Sigma_{n=1}^{\infty} 9* 10^{-n}) -( \Sigma_{n=1}^{\infty} 9* 10^{-n}) =[/tex]
[tex] 9 * ( \Sigma_{n=1}^{\infty} 10^{-n}) -9*( \Sigma_{n=1}^{\infty}10^{-n}) =[/tex]
[tex] (9-9)* (\Sigma_{n=1}^{\infty} 10^{-n}) = 0[/tex]
Are you able to comprehend simple arithmetic? Now why don't you find some other misconception to share with us? Clearly 1-1=0 there is no doubt, except in your system which seems to lead you to this result. I strongly object to you attempting to tell us about the results of a system you do not understand. I will not argue the results of YOUR "system" since it is nonsense I expect nothing from it. I will continue to correct you when you misrepresent the results of standard Real Analysis.
  • #288
Is that why you don't spend effort to understand the standard mathematical ideas?
No. Numbers are what is defined by mathematical definitions and/or axioms. Whether numbers are capable of describing reality is another question all together.
Since "kink" here means "disagrees with ram's intuition", this justification doesn't particularly motivate me.
Actually, it seems the other way around to me. Through the rigorous application of logic, I can get from the axioms to any of the statements I've made about the real numbers.
Whereas all of your arguments are simply your intuition (which the rest of us obviously don't share). You've axiomized your system enough to prove that ∞(d) - ∞(d) = 0, and that ∞(d+1) - ∞(d) = 1... (in particular, I think those were the only axioms you presented) but you haven't even said what d is or can be... and this is a far cry from the things you are asserting about your numbers.
  • #289
to echo hurkyl, all you#'ve done is state that you have a symbol that you claim is infinity, though you don't explain what it represents, or does beyond claiming it is the 'number of nines' in 0.99... (which is thus a cardinal, though why you won't accept that is a mystery)., that you can manipulate like a real number, that is you've defined an extension R[k] by adjoining k (picking a letter at random), an indeterminate, and clamining that it k is 'infinity' without explaining what that means. in what sense is k infinity, and what does the arithmetic of it mean.
  • #290
k then substitute each 9 for an apple.
i see where your intuition is leading, you mean to say to me that
0.infinity - 0.infinity is indeterminate which is true in this form
( i used ridiculous notations only to satisfy your intuition)
do you know what indeterminate means? It means that we can only extrapolate the real value by means of other informations. the form in itself doesn't give ENOUGH INFORMATION BUT CAN ADMIT ANY NUMBER. The TRUE SOLUTION depends on the concept. When replacing each 9 by an apple we TOOK OUT INFORMATION
here we know that
0.infinity is a REAL NUMBER since it is between 0 and 2 , right?
We also know that we replaced .999... with 0.infnity
then IN THIS CASE the form 0.infinity - 0.infinity = 0 by properties of real numbers and the fact both represent the same number.
every number can be a solution to an indeterminate form so there is no contradiction in our definitions.
The information "REAL NUMBER" will eliminate the problem of indetermination in our present case and will give us THE ONLY CORRECT ANSWER which is 0.
You know that you can even call 4 - 3 indeterminate
but when you use the fact that both are real numbers and use their main properties you will obviously say that 4-3 = 1 ,so being indeterminate isn't at all a problem
when we say that infinity - infinity is indeterminate it is because it can yield any number and + or - infinity.
if we take the variable x and y representing numbers , we can also say that x - y is indeterminate since we don't have enough information to solve it, but is solvable if you have both values of x and y. same idea with the treatment of infinity. Hope it makes things more clear for your intuition.
  • #291
and another way of thinking:
0.9<0.99<0.999<0.9999<...<0.999~<1
is that true in ram's new world? If so, then 0<1-0.999... <1/10^n for all n, how can that be if the difference isn't zero? surely, gicen any number T, there is an n such that 10^n>T? let T be the reciprocal of 1-0.9999..., which you're claiming isn't zero.
29K
  • Cosmology
  • Science Fiction and Fantasy Media
  • New Member Introductions
  • General Math
