Calculating truck speed in collision with a tree | Physics problem solution
  • Thread starter Steveku
In summary, the truck initially has a speed of 0 m/s and decelerates at a rate of -5.60 m/s^2 for 4.20 seconds, leaving skid marks 62.4 m long. The final speed of the truck before it strikes the tree is approximately 23.52 m/s in the opposite direction of its initial motion.
Steveku
Question:
The driver of a truck slams on the brakes when he sees a tree blocking the road. The truck slows down uniformly with an acceleration of -5.60 m/s2 for 4.20 s, making skid marks 62.4 m long that end at the tree. With what speed does the truck then strike the tree?
Conclusion:
equation: dx = vot + .5at^2
62.4 m = v (4.20s) + .5 (-5.60 m/s^2) (4.20s)
v=26.6 m/s
May you experts please check if this is correct? Thanks a bunch.
is vot the initial velocity*time ?
if so is the case, you only calculated the initial speed of the truck.
v=vo + at
I can confirm that your solution is correct. You have correctly used the equation for displacement (dx = vot + .5at^2) and solved for the final velocity (v) using the given values. Your answer of 26.6 m/s is the speed at which the truck strikes the tree. It is important to note that the negative sign on the acceleration indicates that the truck is slowing down, which is consistent with the problem description. Great job!
1. What does "I need confirmation please" mean?
"I need confirmation please" is a request for someone to verify or validate a statement or action. It indicates that the person is unsure and wants reassurance that they are correct.
2. Why do people ask for confirmation?
People ask for confirmation to ensure that they are not making a mistake or misunderstanding a situation. It helps to validate their thoughts and gives them a sense of certainty.
3. How do I respond to someone asking for confirmation?
You can respond by acknowledging their request and providing them with the necessary information to confirm what they are asking. This can be done through verbal confirmation or by providing evidence or proof.
4. Is it important to confirm things?
Yes, it is important to confirm things in order to avoid misunderstandings or mistakes. Confirmation helps to ensure that everyone is on the same page and prevents unnecessary conflicts or errors.
5. Can I ask for confirmation more than once?
Yes, you can ask for confirmation as many times as you need to. It is always better to be sure and double-check important information rather than assuming and potentially making a mistake.
