Homework Help: I need help here
  1. Dec 7, 2009 #1
    A steel rod 4.00 cm in diameter is heated so that its temperature increases by 70.0 C. it is then fastened between tow rigid supports. The rod is allowed to cool to its original temperature. Assuming that Young's modulus for the steel is 20.6 * 10^10 N/m^2
    and that its avarege coefficient of linear expansion is 11 * 10^-6 1/C , Calculate the
    tension in the rod.
    2. Relevant equations
    Delta L = L1 * alfa ( avarege coefficient of linear expansion ) * delta T
    and
    F / A = Y delta L / L
    3. The attempt at a solution
    I found delta L / L from first law above
    then i found tension from second law
    Is this true ?? please i need the answer today
    Best wishes for you
  3. Dec 7, 2009 #2
    please help me
    today the last time for answer
  4. Dec 8, 2009 #3
    Redbelly98
    Staff Emeritus
    Your method is correct.
  5. Dec 8, 2009 #4
    But i doubt in my method because the rod's length will decrease by cooling
    and it will exert force on supporter
    and my equation for solution contain avarege coefficient of linear expansion
    not for compression .... understand me ?
  6. Dec 8, 2009 #5
    Redbelly98
    Staff Emeritus
    The coefficient of expansion applies equally to the case of cooling/contraction.
