What are Limiting Reactants & How to Find Them
  • Thread starter Maroc
  • Tags
    Homework
In summary, limiting reactants, also known as limiting reagents, are the chemicals that determine how far a reaction will go before stopping. They can be managed by using excess of the other reactants or by using the stoichiometric amount of each reactant. To determine which reactant is limiting, one can use the limiting reagent formula, which compares the moles of each reactant and determines if one is in excess or if they are balanced.
Maroc
I just want a better understanding on what is limitant reactants are and how you go upon getting them?
if this is consider a hmwk problem please move it
Chemistry news on Phys.org
I think you mean "limiting" reactants. Anyways, limiting reactants are the reactants that you would run out of first during the reaction. They depend both on the stoichiometry and how much you initially start with. You can manage which reactant is limiting by using excess of the other reactants. To not have any excess, then use the stoichiometric amount of each reactant.
thanks!
in chemistry, the limiting reagent, also known as the "limiting reactant", is the chemical that determines how far the reaction will go before the chemical in question gets "used up", causing the reaction to stop. The chemical of which there are fewer moles than the proportion requires is the limiting reagent
Consider a typical thermite reaction:
If 20.0 g of Fe2O3 are reacted with 8.00 g Al(s) in the thermite reaction, Which reactant is limiting?.
First, determine how many moles of Fe(l) can be produced from either reactant.
Moles produced of Fe from reactant Fe2O3
Moles produced of Fe from reactant Al
Because the moles Fe produced from Fe2O3(0.254mol) is less than the moles Fe produced from Al(0.297mol), Fe2O3 is the limiting reagent.
By looking at chemical equation for the thermite reaction, the limiting reagent can be found based on the ratio of moles of one reactant to another and the total atomic mass of the reactant compounds.
Limiting reagent formula
There is a much simpler formula which can be used. However, you must first calculate the moles of both of the reagents in the reaction. Once the number of moles have been figured out, just simply fill in this equation (reagent 1 being the first reactant and 2 being the second):
When the answer to the formula is less than zero, reagent 1 is the excess reagent. When the answer is larger than zero, reagent 1 is the limiting reagent. The number shows how much in excess one reagent is from another. If the answer for the formula is zero, both reagents are perfectly balanced. The unit of an answer is in moles.
1. What is a limiting reactant?
A limiting reactant is the reactant in a chemical reaction that is completely used up, limiting the amount of product that can be formed.
2. How do you determine the limiting reactant?
To determine the limiting reactant, you must calculate the amount of product that can be formed from each reactant. The reactant that produces the smallest amount of product is the limiting reactant.
3. Why is it important to identify the limiting reactant?
Identifying the limiting reactant is important because it allows you to predict the maximum amount of product that can be formed in a chemical reaction. It also helps to ensure that all reactants are used efficiently, minimizing waste.
4. Can the limiting reactant change during a reaction?
Yes, the limiting reactant can change during a reaction if the amounts of reactants are not in the correct ratio. If one reactant is completely used up, then another reactant may become the limiting reactant.
5. What is the difference between a limiting reactant and an excess reactant?
A limiting reactant is completely consumed in a chemical reaction, while an excess reactant is left over after the reaction is complete. The excess reactant is not directly involved in the reaction and does not affect the amount of product that can be formed.
