I need help with an entropy integral!
  1. Nov 6, 2005 #1
    I know the final and initial temperatures of .259kg of aluminum. Specific heat of almuninum is 900 J/(kg*K).
    The aluminum is cooled from 373K to 333.45K. I need to find the entropy change. This is what I did:
    let c = specific heat, m = mass, T = final temperature
    Q = cm(T - 373) <=> Q = Tcm - 373cm <=> T = Q/cm + 373
    Now that I had T in terms of Q, I subsituted it into the entropy integral:
    delta S = [integral from initial heat to final heat] (Q/cm + 373) dQ
    Initial heat lost is cm(373K-373K) = 0, final amount of heat lost is cm(333.45K-373K) = -9219 J
    My integration yielded -3.256 x 10^6 J/K. The right answer should be only around -20 j/k or so. I am WAY off, but my approach seems like it should work.
    What did I do wrong?
  3. Nov 7, 2005 #2
    lightgrav
    if you integrate dQ/T , instead of T dQ , you might get closer to 25 J/K
  4. Nov 7, 2005 #3
    :surprised
    :rofl:
  5. Nov 7, 2005 #4
    The only problem is that it gives a horrible integral (partial fraction decomposition???? :cry: )
    This is much better:
    dQ =cmdT
    so integrate
    cm [integral from initial temp to final temp] dT/T
    Ahhhhhhh... How much nicer. :biggrin:
