Lisun
- 1
I want test my street lamp get lumen, lumen efficiency and color temperature, how can I get these data?
Lisun said:I want test my street lamp get lumen, lumen efficiency and color temperature, how can I get these data?
To test your street lamp, you will need to follow these steps:
If your street lamp is not working, you should first check the power source and light bulb to make sure they are functioning properly. If those are not the issue, it could be a problem with the wiring or the sensor. It is best to contact a professional electrician to diagnose and fix the problem.
It is recommended to test your street lamp at least once a month to ensure it is working properly. However, if you notice any issues or changes in the light, it is best to test it more frequently and address any problems as soon as possible.
Yes, you can test your street lamp during the day. However, it may be more difficult to see if the light is working properly. It is best to test it at night when it is dark to get a better idea of its functionality.
You can tell if your street lamp is energy efficient by looking at its wattage and lumens. A lower wattage and higher lumens indicate a more energy-efficient street lamp. Additionally, you can check for any energy efficiency certifications or ratings on the street lamp itself.
