shanepitts
- 84
- 1
Noting that ice expands by about 9%, why isn't it possible ot build a heat engine from this natural process?
russ_watters said:It would be possible, but I'm not sure what the benefit would be. It could generate a huge force, but with very slow motion.
Not that I know of.shanepitts said:Are there any contemporary ice engines in use?
This process occurs naturally in breaking up exposed rock surfaces, causing what is called "exfoliation.".Scott said:You could. The freeze-thaw cycle makes it for a slow engine. It is possible to use this method for quarrying granite - drill holes, fill with water, let it freeze and thaw, repeat with more water. And, of course, that process occurs naturally in the process of destroying roads and bridges.
If it were economically useful there probably would be so the fact that there aren't any suggests that it's not and that would be why.shanepitts said:Are there any contemporary ice engines in use?
"Exploring the Limits of Heat Engines with Ice Expansion" is a scientific experiment that investigates the potential of using ice expansion as a source of energy in heat engines. It involves studying the expansion and contraction of water as it freezes and melts, and how this can be harnessed to generate power.
This research is important because it has the potential to provide a more sustainable and environmentally friendly source of energy. If successful, it could lead to the development of more efficient heat engines and reduce our reliance on fossil fuels.
In a heat engine, the expansion of a substance (such as water) is used to create mechanical work. When water freezes, it expands and exerts pressure on its surroundings. This pressure can be harnessed to turn a turbine and generate electricity.
One of the main challenges is finding a way to control the timing and rate of expansion and contraction of water in a heat engine. This requires precise temperature control and insulation to prevent energy loss. Additionally, the efficiency of the heat engine must be optimized to make the process viable for practical use.
If successful, this research could have a wide range of applications, including powering vehicles, homes, and even entire cities. It could also have important implications for renewable energy and climate change mitigation efforts.
