Ideal and Factor Ring Problem: Proving A=R When 1 is an Element of A
  • Thread starter Benzoate
  • Tags
    Ring
In summary, if A is an ideal of a ring R and 1 belongs to A, then A must be equal to R. This can be proven by understanding the definition of an ideal, which states that for all elements a in A, and for all elements x in R, the product x*a must also be in A. Therefore, if 1 is in A and A is a subset of R, then A must be equal to R.
Benzoate
422
If A is an ideal of a ring R and 1 belongs to A, prove that A=R.
I said that r should an element of R. and since A is ideal to ring R and 1 is an element of A , then ar should be an element of A . 1 must be an element of a which is an element of ar which is an element of A. Therefore 1*ra=ar*1=> 1 is an element of R. Therefore,R=A
1 must be an element of a doesn't mean anything... what the heck is a supposed to be anyway? I'm assuming it's an element of A maybe... at any rate, nothing can be an element of ar as ar is simply a member of the ring, and you have no reason to believe it's a set.
You realize an ideal is defined such that if a is in A, then for all x in R, x*a is in A?
1. What is an ideal ring?
An ideal ring is a mathematical structure consisting of a set of elements and two operations, usually addition and multiplication. The set of elements forms a ring, and the ideal is a subset of this ring that is closed under addition and multiplication by any element of the ring. This means that when an element of the ideal is added or multiplied by any element of the ring, the result is still within the ideal.
2. What is a factor ring?
A factor ring, also known as a quotient ring, is a ring that is formed by dividing a larger ring by an ideal. The elements of the factor ring are the cosets of the ideal, and the operations of addition and multiplication are defined based on the coset representatives. The factor ring captures the essential properties of the larger ring, while also simplifying its structure.
3. What is the ideal and factor ring problem?
The ideal and factor ring problem involves finding the ideals and factor rings of a given ring. This can be a challenging task, as it requires understanding the properties and structure of both the original ring and the ideal. It is a fundamental problem in ring theory and has applications in many areas of mathematics.
4. How is the ideal and factor ring problem useful?
The ideal and factor ring problem is useful for understanding and classifying rings, as well as for solving more complex problems in ring theory. It also has applications in other areas of mathematics, such as algebraic geometry and algebraic number theory. In addition, the study of ideals and factor rings can lead to a deeper understanding of the structure and properties of rings.
5. What are some strategies for solving the ideal and factor ring problem?
Some strategies for solving the ideal and factor ring problem include using the properties of ideals, such as containment and generation, to identify and construct new ideals. It can also be helpful to use isomorphisms and homomorphisms to relate the original ring to a simpler or more familiar ring. Additionally, understanding the underlying structure and properties of the original ring can provide insight into the ideals and factor rings that may exist.
