Homework Help: Ideal Gas Law Application
  1. Feb 6, 2008 #1
    [SOLVED] Ideal Gas Law Application
    One Sunday morning a family takes an automobile trip to Grandma's. At the start of the trip, the temperature is 288K (15C), and the gauge pressure in the tires is 32lb/in^2 (psi). (The gauge pressure is the excess over 14.5 psi, the exterior air pressure.) After an hour's ride over an interstate highway, the gauge pressure in the tires is 38 psi. What is the temperature of the air in the tires, assuming that air behaves as an ideal gas? Neglect any changes in volume of the tires.
    2. Relevant equations
    PV=nRT
    3. The attempt at a solution
    3. After working around with the universal gas law, the forumla I used is: T2=(P2*T1)/P1
    T2=(38/32)*288=342K
    342-273=69C
    The textbook gives the answer 52C. What am I doing wrong? Did I use the wrong units?
  3. Feb 6, 2008 #2
    Dick
    They already told you. Gauge pressure is pressure above 14.5 psi. Try solving T2=(38+14.5)*T1/(32+14.5).
  4. Feb 7, 2008 #3
    Hmmm, I missed that part. What does it mean when the gauge pressure is above 14.5psi?
    I forgot, but why can't you use the celsius scale to do the problem?
  5. Feb 7, 2008 #4
    Dick
    What they meant is that real pressure=14.5psi+gauge pressure. It's the pressure you would read with a tire gauge, for example. If it reads 0psi that just means that the pressure in the tire is the same as atmospheric pressure. You can't use degrees C because 0C=273K, 1C=274K, but 274/273 is NOT equal to 1/0. You tell me what went wrong.
Loading...
