Homework Help: Ideal Rankine Cycle
  1. Apr 3, 2009 #1
    A steam power plant operates on a ideal rankine cycle between the pressure limits of 9 Mpa and 10 kPa. The mass flow rate through the cycle is 25kg/s. The moisture content of the steam at the turbing exit is not to exceed 10%. Determine the minimum turbine inlet temperature.
    2. Relevant equations
    3. The attempt at a solution
    I really have no idea where to even start. I was able to determine the entropy at the turbine inlet and I know the pressure but I just cant seem to figure out how to connect this to the Temperature at the turbine inlet any help would be great.
Draft saved Draft deleted
