Identity of a Weak Acid
  • Thread starter Euler2718
What is the likely identity of a weak acid if a 0.50 mol/L solution of the acid has a pH of 3.18?
HA + H2O <=> H3O + A
[tex] K_{a} = \frac{[P]}{[R]} [/tex]
[tex] [H3O] = 10^{-pH} [/tex]
[/B]
I set up an ICE table with the concentration given, then solved for x using the inverse log formula for [H3O], finally I did the following Ka expression:
[tex] K_{a} = \frac{(6.6 \times 10^{-4})^{2}}{0.5-6.6 \times 10^{-4}} = 8.75 \times 10^{-7} [/tex]
The closets acid to that appears to be carbonic acid (ka = 4.4x10^-7). Any suggestions?
Answers and Replies
Bystander
1,287
You've doubly ionized a diprotic weak acid at a pH of 3.2? Try it again.
Borek
Mentor
28,805
3,297
I am not sure what you mean, Ka is calculated assuming the acid behaves as a monoprotic. That's not a bad assumption for a carbonic acid (no idea if the OP was aware of the problem, but that's another story).
Sadly, pKa of 6.05 doesn't fit any acid commonly used in introductory chemistry courses. Of those used carbonic acid looks best (but still is way off with the pKa1=6.37).
Related Threads on Identity of a Weak Acid
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
