Homework Help: IDL keywords
  1. Nov 23, 2007 #1
    I've created a function inside IDL and I want to be able to specify the binsize.
    That is, I want to have:
    result = myfunction(array, keyword)
    Whenever I add the keyword in the brackets there it says:
    "Keyword parameters not allowed in call."
    2. Relevant code
    FUNCTION histimage, array, binsize=x
    If KEYWORD_SET(x) then $
    count = uintarr(256/x)
    array = array*(1/x)
    array=round(array)
    *end if else begin
    count = uintarr(256)
    for j = 0,255 do begin
    for k = 0,255 do begin
    count(array(j,K)) = count(array(j,k)) + 1
    endfor
    endfor
    Return, count
    END
    Histimage is the name of my function and binsize is the keyword. The point in the code where there is a * shows where I get a compile error as well. I can't see why I get this error and was hoping that someone could tell me if I've used incorrect syntax.
  3. May 13, 2008 #2
    Hi, hope this isn't too late to be of help, I stumbled across this looking for help on keyword syntax.
    In IDL I think you need:
    if keyword_set(x) then blah
    if not keyword_set(x) then bleh
    I think that's why you're getting a compile error at "endif else begin", as it's not the correct syntax for the keyword_set function.
