If I had a cubic metre of solid osmium, a perfect cube....
In summary, the conversation discusses the concept of gravity and its relationship to the strong nuclear force. The speaker suggests that gravity may not be a force in its own right, but rather an artifact of the strong force leaking out from the nuclei of atoms. However, this theory is not supported by evidence and is not in line with current understanding of physics. The conversation also briefly mentions the potential of using mass to bend a light beam, but ultimately concludes that gravity is a well-understood force in the universe.
Peter Hodgson
If i shon a red laser across the surface of the osmium cube 5mm above the solid perfect 1000mm cube, by how many degrees would it be deflected?
This is not a reply it is another question what density and quantity of matter would I require to bend a red laser beam by15 degrees? What I am really asking is how hard is it to bend space time. I am going to suggest that it is too hard to produce the force we mistakenly call gravity.
I suggest what we experience as gravity is not a force in its own right it is an artifact of the strong force leaking out from the nucleii of atoms. Because space time is scale invarient it would be nearly but not quite pinched off around a nucleus. A tiny portal is left to allow a tiny fraction of the strong force to leak out.
  • Skeptical
Likes davenn
First, note that personal theories are not allowed here at PF. So don't expect your post to stay unlocked for very long.
Second, keep in mind that thousands of scientists do work involving either the strong nuclear force or general relativity, and none of their experiments or observations show any unambiguous results that disagree with either theory. In addition, the strong nuclear force literally cannot do what you are claiming it can do. If it can, then its not the strong nuclear force as has been observed in nature, but another force that has so far eluded every scientist in the world and every experiment in their arsenal to date.
We know this because we can make accurate predictions about what should happen involving the strong force and if it were possible that the strong force was responsible for gravity then these predictions would not be correct.
If you're going to disagree with a fundamental part of modern physics, then you're going to need a substantial amount of both evidence and the theory underlying your evidence. And I suspect that you have none of either.
It's not hard. You can do experiments in your basement.
See this video and the others like it:
Ohhh dear, indeed !
Something around the mass of the sun or bigger
You really should learn some real physics
Likes phinds
Yes, it's hard to "produce" gravity in the sense that it's a relatively weak force so it takes a lot of mass to produce even a small gravitational force - we have the entire mass of the Earth producing a gravitational field, and a tiny little refrigerator magnet can outpull that field. Nonetheless...
  • There is a lot of mass in the universe. If your cube of osmium or the entire mass of the Earth isn't enough to produce an interesting deflection of a light beam, we can always try a suitable galaxy instead.
  • Gravity is always attractive so it's always adding up (compare with electromagnetism - very strong, but because of the opposite charges an atom exerts no net electromagnetic force on things near it).
  • Gravitational forces get weaker with distance but never die out.
Putting this all together and actually doing the math, we can show that there is a force that is proportional to mass, and that our current best theories of gravity explain it really well.
Physics Forums is here to explain what modern physics does say, not to entertain new theories based on misunderstandings, so this thread is closed.
Likes davenn and Dale
1. What is osmium?
Osmium is a chemical element with the symbol Os and atomic number 76. It is a hard, brittle, bluish-white transition metal in the platinum group that is found as a trace element in alloys, mainly in platinum ores.
2. How much does a cubic meter of solid osmium weigh?
A cubic meter of solid osmium weighs approximately 22,610 kilograms or 49,815 pounds. This makes it one of the heaviest elements known.
3. What are the properties of solid osmium?
Solid osmium is a very dense and hard metal with a melting point of 3033 degrees Celsius. It is also very resistant to corrosion and has a high electrical conductivity. However, it is also very brittle and can easily break or shatter.
4. Can a cubic meter of solid osmium be found naturally?
No, a cubic meter of solid osmium cannot be found naturally. Osmium is only found in small amounts in the Earth's crust and is usually extracted from platinum ores. It is also very rare and expensive, making it unlikely for a large amount to exist in one place.
5. What would happen if I had a cubic meter of solid osmium?
If you had a cubic meter of solid osmium, you would have a very valuable and heavy piece of metal. It would also be very difficult to handle and transport due to its weight and brittleness. Additionally, the high melting point of osmium would make it very hard to melt down and shape into different forms.
  • Other Physics Topics
  • General Math
9K
