If p(x)= f(x^3), find P'(1)
  • Thread starter Willian93
if p(x)= f(x^3), find P'(1)
can i do the derivative of x^3 is 2x^2, then substitute to get f(2x^2)?, then substitute 1 for x?
Answers and Replies
cepheid
Staff Emeritus
38
Are both p's supposed to have the same case here (i.e. are they the same symbol representing the same function?) If not, then this question doesn't make much sense.
No, not quite. If I understand the problem right, then what you have is a composite function, and you need to use the chain rule, and you need to know what the functional form of f(x) is. Is f(x) given?
One way of looking at it: p(x) = f(g(x)) where g(x) = x3. Hence, a composite function.
Another equivalent way to look at it: f(x3) means, "pass x3 as an argument into the function f." In other words, p(x) is the function you get when you pass u = x3 as an argument into the function f(u), where I have used a different symbol for the argument passed into f in order to be more explicit.
Edit: Those two ways of looking at it are not really different at all, since in the latter case, I just defined a new variable u = g(x) = x3. But I hope that the wording/explanation helps you to understand what is going on.
Char. Limit
Also, the derivative of x^3 is not 2x^2.
HallsofIvy
41,847
965
No. The chain rule says that the derivative of f(g(x)) is f'(g(x))g'(x). (And, as Cepheid said, the derivative of x^3 is NOT "2x^2".)
cepheid
Staff Emeritus
38
Actually, Char. Limit said that. It was a good catch...
