Does the Michelson-Morley Experiment Support the Constant Speed of Light Theory?
  • Thread starter OneEye
In summary, the conversation discusses the concept that the speed of light never differs locally from c and the Michelson-Morley experiment does not show a variation in the speed of light due to gravitational effects. The participants also discuss the possibility of measuring the deformation in spacetime caused by gravitational fields and how this could potentially provide a direct measurement of the variation in c. They also mention the use of reflectors on the moon to gather information about gravitational potential.
OneEye
All right. So, given that the speed of light varies in a gravitational field,
Why, then, does the Michelson-Morley experiment not show a variation in the speed of light?
I mean, we are in a gravitational field. Right?
The speed of light never differs locally from c. If light passes through some measurement apparatus, that apparatus will always say it's going c. Let's say you're in a space station, significantly outside some object's gravitational field. You can infer via time dilation that the light deep in the gravitational field is traveling more slowly than light out of that field, but you cannot measure it directly. If you put a measurement apparatus down in the field, it'll measure the light going c there, too. Of course, you'll measure the apparatus as running slowly!
- Warren
- Warren
If you are removed from a gravitational field you will view an object within the field as being affected by time dilation. This however would not lead to the observation that lgiht was moving more slowly because the distances are stretched so that the light takes more time (on your clock) to cover a greater distance (you measurments) giving c. The person inside the field measures a smaller distance and a smaller time, still getting c.
Isn't that exactly what I just said? You can infer that the speed of light goes slower than c inside a gravitational field, but you cannot ever measure it directly.
- Warren
- Warren
you can't infer that. You would be wrong.
you can measure it by sending a signal into someone inside the field, them replying (say with a mirror) and you then use the total time measured by you, and the equations of general relativity to calculate the spacetime interval transversed by the signal from which you can calculate the speed, and you will get c.
Sorry, I'm not wrong. Can you show me your math?
- Warren
And I hope you're aware that the interval is invariant! :rofl:
- Warren
Another way to say this is that
"at every event in spacetime, there is a light cone."
I guess what I'm thinking is this: Imagine that we had an apparatus which extended from Mercury to Mars. Would we not be able to measure the deformation in space-time caused by the various gravitic fields involved, and thus come up with a direct measurement of the variation in c which is caused by gravitic effects? I understand that such deformations will be shared by the measruing device, but if the device is long enough to bridge several such deformations, then should we not be able to directly measure thse deformations?
(Sorry about my plebeian terminology here. Please, if you can, tolerate the sci-fi language and decode it into something sensible.)
How often (in time or distance) would you measure the light (to track its position)? Would you only measure it at beginning and end, or several times along the path?
EDIT- Here is a link I found that seems to address your question quite nicely, if I indeed understand the root of your question. The explanation is short and nontechnical ;)
http://www.hitxp.com/phy/rel/gr/261102.htm
The key thing to understand is the difference between inertial and accelerated frames. And why no global inertial frames exist in GR, only local inertial frames.
BTW I hope I got that right :redface: It's been a while, and I'm no expert.
Okay, this is the 3rd and last time I will edit this post- promise. The reason I think the problem lies in an understanding of accelerated and inertial frames is because your idea of making the experiment larger suggests to me that you want to move towards a more "global" view. Perhaps I am mistaken.
- Warren
UhOh, I hope math is only required of challengers :uhh:
What happens in a singularity, such as a black hole? There is no movement, so it would seem to be fallacious to speak of light as having any velocity. However, if you attempted to calculate the velocity, given zero passage of time, you would get an indeterminate answer.
There are in fact reflectors that have been placed on the moon. What do you suppose they are for? The surface of the moon is at a stark difference in gravitational potential to the surface of the earth.
Bon. But you neglected to post the most important piece of information: What have these reflectors told us?
The answer to your question is YES, OneEye. And this measurement has already been done several times. Shapiro was the first to detect it (in 1970's?) bouncing radar beams off Venus (when it was in solar opposition), and likewise signals have been bounced off Mars, and also from the Voyager spacecraft s. All passed EM signals through the the solar gravitational field (planetary fields are far to small for detection) and all show a time delay that is consistent with Gen. Relativity (usually in tens of microseconds). This effect is typically referred to as the 'Shapiro time delay' and is well known in scientific literature and Nasa in general. :smile:
Creator
Excellent. Thanks for the info. How, exactly, this is to be understood - the fact that c, in a vacuum, is inconstant over large distances - is a different question. I appreciate how Dr. Einstein would explain this phenomenon. But I have long suspected the Michelson-Morley experiment as being too narrow in scope to really answer the broader questions.
I don't mean to start anything. I'm happy with the information you've given. But it's certainly provocative in more directions than strict orthodoxy would allow.
I must say though, as a postscript, that I am surprised at those correspondents who took a doctrinaire position in response to my question. I won't mention names (too lazy to look it up), but at least one person said that, No, no such experiments could not possibly yield such results, since relativity did not allow the observation of variations of c in a vaccuum.
I am surprised that anyone was willing to answer so hastily. I had hoped for better.
I was hoping that would send you on a little search for more information about it (I'm lazy, too :wink: ). Anyway, AFAIK, they have been used to determine a precise distance to the moon. I don't know any more detail than that.
Ok, please excuse this question if it is pathetic. But I thought light slows down when it changes to more dense surfaces. But then I was told that [itex]c[/itex] was constant...
Second, If light stops in a black hole, does it not need to decelerate to stop - or to die for say, wouldn't that involve light changing speeds
I mean, I understand that [itex]c[/itex] is constant, but can time dilation explain these two concepts?
c is a constant in relativity. Light in a vacuum travels at c. Light traveling in other media is interacting with the matter in the media, and the time for these interactions has to be added to its transit time, thus it takes longer to pass through.
Light does not stop in a black hole; it falls in. Once in. it can't get out.
But should it not be, "c is constant in Special Relativity, but varies with acceleration in General Relativity?"
I don't mean to quibble - perhaps I am just not getting the terminology right.
And I had thought that light never crossed the even horizon of the black hole, because the curvature of space was such that the "escape velocity" over the event horizon was greater than c.
Or is that just a science fiction version of reality?
If you consider c to represent a tiny proper distance traversed by light in a tiny proper time, then c is also the speed in GR. Incidently, it shows up ubiquitously in both theories, so it is without question a constant in both theories at least in the same sense that G is a constant in Newton's universal law of gravitation.
That's one way to think of it, a lot closer to Newton's corpuscular notion of light. In GR, you can think of it as space itself falling into the singularity faster than light.
turin - Thanks - clear, concise, straightforward. Well put.
1. What is an "Ignorant Question"?
An "Ignorant Question" is a question that is asked without any prior knowledge or understanding of the topic at hand. It is often asked out of genuine curiosity and a desire to learn.
2. Why are "Ignorant Questions" important in science?
"Ignorant Questions" are important in science because they allow scientists to identify knowledge gaps and areas for further research. They also encourage critical thinking and help to challenge existing theories and ideas.
3. Are "Ignorant Questions" discouraged in science?
No, "Ignorant Questions" are not discouraged in science. In fact, they are encouraged as they can lead to new discoveries and advancements in scientific knowledge. However, it is important to ask questions with an open mind and a willingness to learn.
4. How can scientists approach "Ignorant Questions" in a respectful manner?
Scientists can approach "Ignorant Questions" in a respectful manner by actively listening, acknowledging the question, and providing a clear and informative response. They should also avoid belittling or dismissing the question and instead foster a positive and inclusive learning environment.
5. Can "Ignorant Questions" lead to breakthroughs in science?
Yes, "Ignorant Questions" can certainly lead to breakthroughs in science. Many great scientific discoveries and advancements have been made through asking seemingly simple or "ignorant" questions. It is important for scientists to remain open-minded and curious, as even the most basic questions can lead to groundbreaking discoveries.
