Calculating Force to Propel Boat Across Shallow Lake
In summary, the figure shows a worker poling a boat-a very efficient mode of transportation-across a shallow lake. He pushes parallel to the length of the light pole, exerting on the bottom of the lake a force of 245 N. Assume the pole lies in the vertical plane containing the boat's keel.
^Kris
The figure below shows a worker poling a boat-a very efficient mode of transportation-across a shallow lake. He pushes parallel to the length of the light pole, exerting on the bottom of the lake a force of 245 N. Assume the pole lies in the vertical plane containing the boat's keel. At one moment, the pole makes an angle of 35.0° with the vertical and the water exerts a horizontal drag force of 47.5 N on the boat, opposite to its forward velocity of magnitude 0.857 m/s. The mass of the boat including its cargo and the worker is 390 kg.
(a) The water exerts a buoyant force vertically upward on the boat. Find the magnitude of this force.
(b) Model the forces as constant over a short interval of time to find the velocity of the boat 0.450 s after the moment described.
F=ma
First of all, I would like to say thank you for everyone's help in advance. I stumbled across this gem of a site while seeking help on my homework. I think its an awesome site.
I got part (a) as 3681.4737 N . I found this by finding the normal force on the boat n = Mg then finding the push force from the pole on the ground in the y direction and subtracting that from the normal.
I just don't understand what the heck part b is asking. Any help in any sort of direction would be great. I'm pretty sure its something simple, I just cannot think of anything to apply. It says the final answer should be in m/s. Thanks again.
I think it means that if F is held constant over a period t, then so would acceleration. Knowing that, you can find final V using simple kinematics, given a and t.
Ok so I used F=ma to find a. I found the horizontal F by doing 245cos(35) and got 200.6922, and then divided that by the mass of the boat which is 390kg and got .3928m/s^2. I know the acceleration, and the time, but I do not know the initial V, therefore how can I find the Final V?
How about [tex] a = \frac{dv}{dt} [/tex]
I only skimmed the problem, but isn't initial v given?
I missed the part with the .857m/s as the initial, but I tried that and put it into the answer block and it says its wrong. I used V = Vi + at to solve for the final speed, but the online answer is saying "Did you accidentally divide or take the inverse in your calculation?" which i don't think I did and I think I carried out the problem correct. Unless I need to incorporate the 47.5 N of force opposed to the keel?
Wow, I am an idiot. Thank you all for the help. I had to find the acceleration of the opposing force and subtract that from the acceleration of the boat, and then add that to the initial speed given. Thanks again.
Well yes you do, You said you had about 200N forwards, and we're given that there is 47.5 N backwards. Sum the forces up, re-calculate acceleration. Use your constant acceleration formula again.
Provided your 200N is correct then you should be fine.
Just re-reading what you've done. 35 degrees is with the vertical (as given in the question).
To find the horizontal you should take a sine, not a cosine.
That's weird b/c I got the correct answer according to online, so why did the cosine calculation provide the correct answer for me?
1. How do I calculate the force needed to propel a boat across a shallow lake?
The force needed to propel a boat across a shallow lake can be calculated by using the formula F = m x a, where F is the force, m is the mass of the boat, and a is the acceleration. You will also need to take into account the resistance of the water and any other external forces acting on the boat.
2. What factors affect the force needed to propel a boat across a shallow lake?
The force needed to propel a boat across a shallow lake is influenced by several factors, including the size and weight of the boat, the shape of the hull, the speed of the boat, and the resistance of the water. Other external factors such as wind speed and direction may also impact the force needed.
3. Is there a specific formula for calculating the force to propel a boat across a shallow lake?
As mentioned before, the formula F = m x a can be used to calculate the force needed to propel a boat across a shallow lake. However, this formula may need to be adjusted to account for different variables such as water resistance and external forces.
4. How does the shape of the boat affect the force needed to propel it across a shallow lake?
The shape of the boat can greatly impact the force needed to propel it across a shallow lake. A boat with a more streamlined hull will experience less resistance from the water, therefore requiring less force to move through it. On the other hand, a boat with a wider, flatter hull will have more surface area in contact with the water, resulting in higher resistance and requiring more force to move.
5. Is there a way to reduce the force needed to propel a boat across a shallow lake?
There are several ways to reduce the force needed to propel a boat across a shallow lake. One way is to make the boat more streamlined and aerodynamic, reducing the resistance from the water. Another way is to reduce the weight of the boat, which will require less force to move. Additionally, using more efficient propulsion methods such as a motor or oars can also help reduce the force needed.
