Immersing an object in a fluid
  • Thread starter fluidistic
  • Tags
    Fluid
In summary: I get my answer but with a positive sign... how is that possible?A positive force is a force with the same direction than the x axis, namely a force pointing at the bottom of the liquid. When you integrate from the free surface to the bottom of the liquid, the pressure increases, causing the buoyant force to also increase in magnitude.
fluidistic
261
Consider a liquid whose density [tex]\rho[/tex] varies such that [tex]\rho (x)=Kx[/tex] where [tex]K[/tex] is a constant and [tex]x[/tex] is measured from the surface of the liquid. The liquid is contained into a cylinder, and the liquid height is [tex]L=\frac{2m}{AeK}[/tex].
We introduce a parallelepiped horizontally where its upper and bottom surfaces are worth [tex]A[/tex], its mass is [tex]m[/tex] and its height is [tex]2e[/tex].
Depreciate the viscosity of the liquid.
1)Determine the equilibrium position of the mass.
2)Determine the motion equation of it, if we apart it a [tex]\Delta x[/tex] from its equilibrium position.
None given.
I don't think I can apply Archimedes' principle because the fluid hasn't a constant density.
What I did was to calculate the pressure difference between the upper and bottom surfaces of the mass.
if X is the distance between the surface of the liquid and the center of mass of the parallelepiped, I get that the force acting on the upper surface is [tex]AK\int _0^{X-e}xdx=-\frac{AK}{2}(X-e)^2[/tex].
Similarly I get the force acting on the bottom surface :[tex]\frac{AK}{2}(X+e)^2[/tex].
I sum them up to get the total force due to the pressure's difference : [tex]2AKeX[/tex].
This force acts upward. However to calculate the net force on the mass, I have to add the last force : its weight : [tex]mg[/tex].
When the mass is at equilibrium, [tex]mg=2AKeX \Rightarrow X=\frac{mg}{2AKe}[/tex].
Am I right? If so, I'll try to continue alone.
You are correct here.
It is better to calculate the pressure as a function of depth from the free surface then calculate the difference between the upward and downward force. You will see that the upward (buoyant) force has two terms not just one.
Thanks for helping!
Ok, glad to know this.
Ok so I went wrong somewhere.
[tex]P=\frac{F}{A}=\rho (x)gx=Kx^2g[/tex]... or I can't even use the formula [tex]P=\rho g h[/tex]?
No. Consider a rectangular element of fluid of area A and thickness dx such that its upper face is at the free surface. What is the pressure at the bottom of the element? To find the pressure at depth x, integrate from zero to x.
[tex]P_0[/tex] : atmospheric pressure.
So the pressure at the bottom of the element is [tex]P_0+\rho gdx[/tex]. Integrating, [tex]P_0+g\int _0^h \rho (x)dx=P_0+\frac{Kgh^2}{2}=P(h)[/tex].
Correct. Now proceed to find the buoyant force.
Force=PA thus at the bottom of the mass, [tex]F=-\frac{AKg(X+e)^2}{2}[/tex] while at the top of it, [tex]F=\frac{AKg(X+e)^2}{2}[/tex], adding them up, the buoyant force is [tex]-2AKgeX[/tex], which negative sign seems good since I took the positive sense to be from the surface of the water to the bottom. Ok so in my first post I forgot the g factor and the negative sign disappeared.
Did I go wrong? I'd get [tex]mg=-2AKgeX\Rightarrow X=-\frac{m}{2AKe}[/tex], hmm yes I went wrong. I shouldn't have this negative sign at least.
I understand that e is half the height of the parallelepiped. How have you defined X?
Oh sorry, X is the depth of the center of mass of the parallelepiped.
Then at the bottom of the mass, the force is up and equal to
[tex]
F_{Bot}=+\frac{AKg(X+e)^2}{2}
[/tex]
and at the top the force is
[tex]
F_{Top}=-\frac{AKg(X-e)^2}{2}
[/tex]
What is the sum of the two which should be the buoyant force?
[tex]
[/tex]
[tex]
[/tex]
I get my answer but with a positive sign... how is that possible? A positive force is a force with the same direction than the x axis, namely a force pointing at the bottom of the tank.
My convention is that "up" is positive and "down" is negative. That's why the force acting at the bottom of the box is Positive and the force acting at the top is negative.
Ah ok, so we've the same result. Then I just have to equate this with mg, right?
Right, on the assumption that the entire mass is immersed in the fluid and sinks until it reaches equilibrium at some depth denoted by X.
Ok, thanks a lot for your help.:smile:
1. What is meant by "immersing an object in a fluid?"
Immersing an object in a fluid refers to the process of submerging an object completely in a liquid. This liquid can be water, oil, or any other type of fluid.
2. Why is it important to immerse objects in fluids during experiments?
Immersing objects in fluids allows scientists to study the effects of buoyancy, drag, and other fluid forces on the object. This is particularly important in experiments involving aerodynamics, hydrodynamics, and fluid mechanics.
3. How does the density of the fluid affect the immersion of an object?
The density of the fluid plays a significant role in determining the buoyant force acting on the object. If the density of the object is greater than the density of the fluid, it will sink. If the density of the object is less than the density of the fluid, it will float.
4. Can the shape and size of the object affect its immersion in a fluid?
Yes, the shape and size of the object can have a significant impact on its immersion in a fluid. The shape of the object can affect the distribution of drag and buoyancy forces, while the size of the object can affect the overall magnitude of these forces.
5. How can scientists use the concept of immersing objects in fluids in real-world applications?
The concept of immersing objects in fluids has various practical applications, such as in ship design, aircraft design, and even in the development of sports equipment. It also plays a crucial role in understanding natural phenomena, such as the movement of marine animals in water.
