Homework Help: Impact loading: Pogo stick
  1. Aug 10, 2011 #1
    http://i.imgur.com/CnAcu.png
    2. Relevant equations
    So, I'm having trouble figuring out how to start this problem.
    I'm trying to use this equation:
    Fe = W(1+[itex]\sqrt{1+2h/\deltast}[/itex]
    and [itex]\delta[/itex]st = W/k
    3. The attempt at a solution
    This is my attempt at summing the forces:
    [itex]\Sigma[/itex]F = 100 lbf/in * [itex]\delta[/itex] + Weight of child
    Thanks
  3. Aug 12, 2011 #2
    PhanthomJay
    You should first calculate the spring deformation under 400 pounds of max force in the spring, using Hooke's law. Then use conservation of energy equation.
  4. Aug 14, 2011 #3
    nvn
    danief: Your relevant equations are correct; and they are not a function of maximum deflection. You can change your approach as PhanthomJay suggests; or you can instead just use the approach you already started writing in your relevant equations, as follows.
    First, convert everything to a coherent measurement system. Next, the problem statement gives you h = 0.1016 m, Fe = 1779.2886 N, and spring constant k. Now simply solve your relevant equation for weight W. You are done.
    (By the way, ignore your attempt at summing forces in part 3 of post 1, which is incorrect.) Also, please do not post wide images directly to the forum page. Just post a text link to wide images.
Loading...
