Understanding Frequency Effects on Impedance: Resistors, Capacitors & Inductors
  • Thread starter viola.geek
  • Tags
    Impedance
In summary, impedance is the general term for opposition to current flow in a circuit, which includes resistance, as well as the opposing forces of capacitors and inductors. Frequency affects impedance in a variety of ways, but generally does not have a significant effect on resistance. The standard alternating voltage and frequency in the US is 120 volts and 60 hertz, while in Europe it is 50 hertz. To understand impedance, it is helpful to learn about resistors, capacitors, and inductors, as well as the concepts of phase shift and polar plots. It is important to study and understand these concepts, as they are essential for anyone studying physics or electrical engineering.
viola.geek
While working in a lab this summer, I've been reading up on impedance and AC circuits as much as I can, considering I have to present at the symposium here in August. I'm really confused about a few...parts of impedance, for lack of a better term.
How does frequency affect impedance, in general?
I know: Z = R + jX, Z = R + ZL + ZC = R + j(XL - XC) and XC = 1/[tex]\omega[/tex]*C, XL = [tex]\omega[/tex]*L
But a more general statement would help when it comes to explaining/summing everything up on how frequency affects impedance, especially when explaining it to people who have never studied impedance in depth but have only heard the term before.
How does frequency affect resistors, capacitors, and inductors? Is it just the equations for impedance for each of these?
And when I see |Z| and [tex]\phi[/tex], am I to think of polar plots of impedance? Or something to that effect?
Sorry if I repeated any questions already answered here. I did a search and found nothing. :)
These are good questions, and anyone who plans to major in physics or EE should understand them.
First, resistors are easy. V = I*R; voltage = amps times resistance; power = I2R = V2/R etc. Learn to read the stripes on resistors; black, brown, red orange, yellow, green, blue, violet, grey, white. I would give you a memorable little ditty but the Forum would object.
Second, capacitors. Capacitors store charge. Charge is the time integral of current. Capacitors do not dissipate energy, however. When you put current into a capacitor, the voltage increases. Q = C*V; dQ/dt = I = C*dV/dt. If the voltage is sinusoidal, dV/dt = jwV, where j = a 90 degree phase shift and w = 2 pi*f where f = frequency (e.g., 60 hertz). So I = jwC*V, or V= I/jwC.
Similar for inductances, except they store magnetic energy (current), not charge. V= L*dI/dt = jw*L*I where L = inductance.
So a series RLC circuit has an impedance Z = V/I = R + jwL + 1/jwC = R + jwL - j/wC. Note that j/wC can equal jwL and cancel it out at a certain frequency where w2 = 1/LC. This called a series resonance.
Most homes have refrigerators and other appliances that have electric motors. Electric motors have an impedance that is partly inductive, so the household voltage and current are slightly out of phase. V = I(R + jwL). The power is then I*V*cos(θ), where cos(θ) is called the power factor.
Complex impedance is often plotted on polar plots; reactive (inductive) = +y, resistive = + x. and capacitive = -y.
Many years ago, I worked part time at an electronics lab while I was in college. very valuable experience.
α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ ς σ τ υ φ χ ψ ω
Thank you for your response. :smile:
But what do we mean when we say "phase shift?" Is that just for the polar plot, with a vector |Z| and an angle [tex]\phi[/tex]? I know you can show impedance data on a Bode plot, which has the log |Z| and log ω, but I don't understand why it's the log of each value. Why not just plot |Z| vs. ω? (I asked around in my lab, but no one could explain it.)
I have yet to take an electronic measurements course (or E&M...both classes are this next school year), so maybe this is why I'm confused about this, but what do you mean by "the voltage is sinusoidal" and "j = 90 degree phase shift?"
Is this true for parallel circuits too?
but what do you mean by "the voltage is sinusoidal" and "j = 90 degree phase shift?"?
All our ac power is sinusoidal, meaning that V(t) = V0 sin(wt) = V0 sin (2 pi f t)
If Both the voltage and current are in phase, V = V0 sin(wt) and I = I0 sin (wt).
If the current leads the voltage by 90 degrees, then V = V0 sin(wt) and I = I0 cos (wt). This a 90 degree phase shift.
For parallel resonance, 1/Z = 1/jwL + jwC = (1 - w2LC)/jwL
Resistance is the opposition to current flow...big resistances do not carry current easily and tend to get hot. Impedance is a more general form of opposition to current flow. which indudes resistance, reflecting the opposition of capacitors and inductors to current flow.
In general frequency alters impedance, and hence current flow varies,but in different ways for different circuit components (capacitors and inductors) and does not generally effect resistance at moderate frequencies. At extremely high frequencies even the wiriing in a circuit, that is the wiring sitting on a lab table, can exhibit capacitance and inductance..
In the US the standard alternating voltage and frequency is 120 volts and 60 hertz, that is, 60 cycles per second. In Europe, I'm not sure what the stand voltage is, but standard frequency is 50 hertz.
Try wikipedia at http://en.wikipedia.org/wiki/Electrical_impedance or read any introductory tex on ac circuits.
I also worked in electronics labs at at NYU and Manhattan College; a great experience. Be sure you make the effort to learn as much as you can, you'll be gald you did. good luck.
So, then, impedance's relation to frequency is the equation(s)? (Just to clarify.)
Edit: 1/Z = 1/jωL + jωC --> always the equation for impedance in a parallel circuit? or just that resonant frequency?
Sorry for asking so many questions! I just want to make sure I understand this. :smile:
In a Bode plot, log |Z| is plotted against log ω, and phi against log ω. Why is it the logarithm of each value, except for phi? (My project involves lithium ion batteries, and since I need to cover the background on EIS in my presentation, I'm also trying to anticipate questions...)
1. What is impedance and why is it important?
Impedance is the measure of the opposition to the flow of electric current in a circuit. It is important because it determines the behavior of the circuit and affects the performance of electronic devices.
2. How do resistors, capacitors, and inductors affect impedance?
Resistors, capacitors, and inductors all have different properties that affect the impedance of a circuit. Resistors increase impedance by resisting the flow of current, capacitors decrease impedance by storing and releasing energy, and inductors increase impedance by creating a magnetic field that opposes the current.
3. What is the relationship between frequency and impedance?
The relationship between frequency and impedance is inversely proportional. As frequency increases, the impedance of a circuit decreases and vice versa. This is because higher frequencies allow the current to flow more easily through the circuit, reducing the opposition to its flow.
4. How do you calculate impedance for a circuit with multiple components?
The total impedance of a circuit with multiple components can be calculated using the formula Z = √(R^2 + (Xl - Xc)^2), where R is the resistance, Xl is the inductive reactance, and Xc is the capacitive reactance. Each component's impedance can be calculated using their respective formulas and then added together to find the total impedance.
5. How can understanding frequency effects on impedance help in circuit design?
Understanding how frequency affects impedance is crucial in circuit design as it allows for the selection of the appropriate components to achieve the desired impedance and current flow. It also helps in troubleshooting and optimizing the performance of electronic devices by identifying and addressing any impedance issues in the circuit.
  • Classical Physics
  • Classical Physics
9K
