Impedance seen by input of inverting amplifier
In summary: So you have eliminated the offset voltage caused by the input bias currents, the voltages themselves don't disappear, but they are identical now, so the resulting output voltage is in the same proportion to the input voltage as if the input bias currents were zero.In summary, the impedance seen by the inverting input of an inverting amplifier is just the two feedback resistors, R1 and R2, in parallel. This is due to the fact that the non-inverting input is tied to ground, creating a 'virtual ground' at the inverting input. This eliminates the offset voltage caused by input bias currents, making the output voltage proportional to the input voltage. This can be achieved by adding a resistor from the non-inverting input to ground
dsdsuster
30
Hi,
The book I'm reading references the fact that the impedance seen by the inverting input of an inverting amplifier is just the two feed back resistors, R1 and R2 in parallel.
I'm having trouble seeing this. I understand how the basic voltage divider with one end at Vin and the other at ground can be replaced by its Thevenin equivalent but in this case it seems like the tail of R2 is connected just to some arbitrary output terminal. In fact ground is actually connected to the non-inverting input and it seems to me there's no easy way to create a Thevenin equivalent of the driving source without examining the opamp's innards.
The book goes as far as to redraw the inverting amplifier with the Input voltage in series with (R1,R2 parallel) connected to the inverting terminal with nothing connected to the opamp output so we are essentially have open loop gain. Surely this cannot be equivalent? To give some context, we are looking at the effects of input biasing currents so the Input voltage is grounded. I apologize if this last paragraph is confusing since I can't supply a picture.
My main question is just in what sense is it true that the impedance seen by the inverting input of an inverting amplifier is just the two feed back resistors, R1 and R2 in parallel? I'm struggling to reconcile this with my understanding of the more traditional voltage divider.
Thank you
The inverting input is a 'virtual ground' due to the fact the non-inverting input is tied to ground. The inverted feedback signal nulls the input at the - input terminal as the output voltage changes to the level needed to maintain zero volts at the - terminal.
Maybe this can help. http://electriciantraining.tpub.com/14180/css/14180_107.htm
In fact, with the noninverting input grounded, the voltage at the inverting input to the operational amplifier is so small compared to other voltages in the circuit that it is considered to be VIRTUAL GROUND. (Remember, in a closed-loop operation the inverting and noninverting inputs are at the same potential.)
You are probably reading this in the context of DC off-sets, and being told that for optimum results, the OP-AMP's (+) input should be returned to ground via a resistor equal to the resistance seen by the (-) input of the OP-AMP. As always, to find the Thévenin impedance you short out the voltage sources, in this case Vin and Vout, and you are left with two resistors in parallel.
BTW, R1 is not a "feedback resistor". :approve:
Thank you guys for the replies.
Nascent Oxygen- The scenario you're describing is what I'm trying to do, setting the resistance the (-) terminal sees equal to what the (+) sees. I'm still having trouble seeing how this is related to a voltage divider though and finding the equivalent resistance (+) sees. I'm hoping you can spell things out a bit more for me.
Edit: Or actually I guess I can see where you get R1 and R2 in parallel from, by shorting (+) and ground. *Is this a fair assumption to make though, since we are trying to find the resistance at the (-) terminal to make Vout 0? *Aren't we assuming Vout is 0 before showing it is 0 by doing this?
Also how exactly will this eliminate the offset dc voltage caused by input bias current?
The input impedance of your circuit is R1 unless the amplifier output is saturated.
Adding a resistor from the + input to ground eliminates (in theory) output offset voltage due to input bias (not offset) currents. Input offset current = i02 - i01 where i01 and i02 are the bias currents flowing into each op amp input. Bias current = (i01 + i02)/2. You can eliminate bias current output voltage offset but not offset current output voltage offset.
To understand how a resistor from the + input to ground = R1||R2 eliminates bias current output voltage offset, label the - and + inputs as e1 and e2 respectively. Ground the R1 input and e2 and draw currents i0 flowing into the + and - inputs. Write nodal equations to compute the output Eo. Remember that e1 = e2 (no input offset voltage assumed). You should get Eo = + i0*R2.
Then put a resistor at the + input to ground = R1||R2. Now e2 = -i0*(R1||R2). Recompute your output Eo remembering that e1 = e2. You should get Eo = 0V.
Likes 1 person
It has nothing to do with a potential divider. Set all voltage sources to 0V, position yourself at the (-) terminal of the OP-AMP, and you see 3 resistances to ground all in parallel: R1 to ground, R2 to ground, and the infinite impedance of the OP-AMP's (-) input.
I'd say rude man has explained this better than I could. It makes identical the impedances of the circuits feeding the input transistors forming the differential input of the OP-AMP block.
1. What is the purpose of an inverting amplifier?
An inverting amplifier is used to amplify and invert the input signal, meaning that the output signal is a mirror image of the input signal. This is useful for applications like audio amplifiers and signal processing.
2. How is the impedance seen by the input of an inverting amplifier calculated?
The impedance seen by the input of an inverting amplifier is calculated by taking the parallel combination of the feedback resistor and the input resistor. This effectively decreases the input impedance of the amplifier.
3. How does the input impedance of an inverting amplifier affect the circuit's performance?
The input impedance of an inverting amplifier affects the circuit's performance by influencing the input signal's voltage and current. A lower input impedance can cause a larger voltage drop, while a higher input impedance can cause a smaller voltage drop. This can lead to distortion of the output signal.
4. What is the ideal input impedance for an inverting amplifier?
The ideal input impedance for an inverting amplifier is infinity, meaning that no current will flow into the input. This ensures that the input signal is not affected by the amplifier and the output signal is a true representation of the input signal.
5. How can the input impedance of an inverting amplifier be improved?
The input impedance of an inverting amplifier can be improved by increasing the value of the input resistor or decreasing the value of the feedback resistor. This will increase the parallel impedance and result in a higher input impedance for the amplifier.
  • Electrical Engineering
