Jonathan Scott
- 1,149
How many things can go wrong simultaneously and apparently independently with a gas central heating system? Mine has been stretching credulity to the limits last weekend.
Saturday afternoon, we noticed house getting cold and spotted that pilot light was out. Couldn't get it to relight at all. Phoned our usual plumber / heating engineer but got voice mail saying closed due to illness.
Looked up a "local" emergency plumber (expensive) online, who arrived a couple of hours later. He couldn't get it to light either, but didn't seem to have any real idea why. I mentioned that on a previous occasion we had pilot light go out due to some dirt in the nozzle, so he borrowed a needle to try cleaning it out, and after that the pilot light flame would light. However, it would go out as soon as the igniter button was released. He then said it must be the thermocouple (which senses the flame and holds the gas valve open). I asked if he could do a test to confirm that it was the thermocouple (I assumed that he could check it with a meter and a flame), but he didn't seem to know how to do that, but instead he dismantled a lot of stuff and made a lot of mess (and threw away some bits of the "glass rope" which is supposed to seal the burner area). He also said it could be the thermostat and gas control, but as that doesn't get involved until the whole thing is running I couldn't see how, and he couldn't give a coherent reason. But his final conclusion was that the thermocouple needed replacing; it's a cheap part and easily available.
We then remembered we had the phone number for someone who had previously been a very efficient heating engineer assistant to our normal local plumber, and he said he could get the thermocouple and come and install it Monday morning. So for the rest of Saturday and Sunday we used a gas fire in our living room for heat (using fans to spread it around the house a bit) and used our electric immersion heater for hot water.
So on Monday morning, he came and replaced the thermocouple and it still didn't work, and it only took him moments to prove it must actually be the gas valve operated by the thermocouple that wasn't working.
So he got that part during the day and came back to fit it in the evening. So then the pilot light stayed on and the burner would light. But no water circulated - the boiler got very hot but the outflow pipe remained cold! He then found that the water pump was not working properly (again easily demonstrated), but he happened to have one in the van that he had left over from upgrading a working system in the last few days. But that one didn't work either, and eventually turned out to be in a worse state than our original one (although the system from which it was removed was very small, so it may well have worked there).
So he went out and got a new pump (expensive again) and installed it. And it still seemed to be not working! While he was investigating, he discovered that the backplate wiring for our central heating timer was incorrect, so the combination of functions he was testing (central heating without hot water) did not work.
So he decided to test with hot water instead (adjusting the thermostat to make sure it would come on). But it STILL didn't work. He and I were both getting quite stressed out by that point. However, he then realized that by changing the pump twice he had introduced quite a bit of air into the loop, which might be causing a problem, so he first temporarily connected the pump backwards, which finally seemed to make something flow, then he connected it forwards again, and after some gurgling noises it finally started working properly. Since then it has been working fine so far (somewhat better than before, probably because of the new pump).
However, we are still unable to explain how all these failures occurred simultaneously. It's just about possible that since the thermocouple had been holding the pilot light gas valve open continuously for years, the pilot light getting blocked could have triggered the first operation of the gas valve for a very long time, after which it failed. But how would that link to a pump failure? The heating engineer speculated that perhaps somehow a gradual pump failure caused the boiler to overheat, somehow triggering a problem with the pilot light, and that the gas valve was already about to fail. The bad second pump was just bad luck, as was the incorrect wiring (ignored for now, as we never use heating without also having hot water enabled) preventing the specific test from working.
Although it's all working now, I find it very unsettling to come across everyday things which seem to violate the laws of probability in this way!
