Homework Help: Impossible Problem?
  1. Sep 16, 2010 #1
    Impossible Problem?????????
    Can anyone solve this problem.....
    The age of a machine, x, in years, is related to the probability of breakdown, y, by the formula...
    x = 3 + 1n [y / 1 - y]
    Determine the probability of breakdown for 1, 3 and 10 years.
    You need to explain what you did to acheive each out come.
  3. Sep 16, 2010 #2
    statdad
    Re: Impossible Problem?????????
    In each case you are given a value of [tex] x [/tex] and asked to solve for the corresponding value of [tex] y [/tex]. You need to rearrange the equation you're provided to be able to do that. By the way, parentheses can help you give a clear presentation of your formula:
    x = 3 + ln(y/(1-y))
    is a better way to write your formula if you don't use the latex feature here in this post. written with latex
    [tex]
    x = 3 + \ln \left(\frac y{1-y}\right)
    [/tex]
  4. Sep 16, 2010 #3
    Uh no, this is basic algebra, and you should give it an attempt first.
  5. Sep 16, 2010 #4
    Mark44
    Staff: Mentor
    It's not at all impossible. What you need to do is to solve the equation for y in terms of x; i.e., find the inverse relationship.
    BTW, it's not 1n; it's ln, short for logarithmus naturalis.
    Also, you need another pair of parentheses in your equation, like so: x = 3 + ln [y / (1 - y)]
  6. Sep 16, 2010 #5
    I know i'm supposed to rearrange the equation , but from there on i'm stuck.... can anyone give me a hint or two?
  7. Sep 16, 2010 #6
    HallsofIvy
    x is the time in years and y is the probability of break down. To find "the probability of breakdown for 1, 3 and 10 years", set x equal to 1, 3, and then 10 and solve for y in each equation:
    [tex]x= 3+ ln\left(\frac{y}{1- y}\right)[/tex]
    so you need to solve
    [tex]3+ ln\left(\frac{y}{1- y}\right)= 1[/tex]
    [tex]3+ ln\left(\frac{y}{1- y}\right)= 3[/tex]
    and
    [tex]3+ ln\left(\frac{y}{1- y}\right)= 10[/tex]
    I would start, in each equation by subtracting 3 from both sides. And you invert ln(x) by using its inverse function [itex]e^x[/itex], the exponential function: if ln(y)= x, then [itex]y= e^x[/itex].
  8. Sep 16, 2010 #7
    Ok, so now I've got e^-2 [y / 1 - y] = -2
    How do i get a value for y?
  9. Sep 16, 2010 #8
    What happened to X?
    Subtracting 3 from both sides gives you:
    [tex]x-3 = ln \left( \frac{y}{1-y} \right) [/tex]
  10. Sep 22, 2010 #9
    So here it is........
    We start off with :- x = 3 + 1n [y / 1 - y]
    Using Age of machine is 1 Year x = 1 , we get...
    1 = 3 + ln [y / 1 - y]...............
    Using Exponential e, we get.... 1 - 3 (and Exchange Exponential e for + ln..
    = e^-2 = [ y / 1 - y ]........ (Exponential (e) -2 = 0.135)
    Now here's the 'Magic'...
    We need to make 'y' the subject so we need to rearrange the equation...
    So the Equation becomes.... y = 0.135 / 1 + 0.135
    Which = y = 0.135 / 1.135 = 0.1189............
    The probability of breakdown for 1 year is................ 0.1189
    Have a go at 3 years and 10 years and see if you get the same Answers as I did...
    The probability of breakdown for 3 years is............... 0.5
    The probability of breakdown for 10 years is............. 0.999
  11. Sep 23, 2010 #10
    This is correct. But why not just solve for Y first, then enter the X values as needed?
    You should come up with
    [tex]y = \frac{e^{x-3}}{1+e^{x-3}} = \frac{e^x}{e^3 + e^x}[/tex]
  12. Sep 23, 2010 #11
    Yeah, I like your way of thinking, I 'll keep a note of that. Because up until now I didn't know it could be solved that way. Thanks For the Heads Up.
  13. Sep 23, 2010 #12
    But looking at your idea......it's another way.... But, I get to thinking my way is a lot Simpler. (Algebra is all about reversing the equasion anyway).
    i.e........
    3x + 4 = 19
    3x = 19 - 4
    ...and so on.
    Thanks for your input
  14. Sep 23, 2010 #13
    No problem.
    Of course, what's simple for one person, isn't necessarily simple for another.
    Knowing that this is a homework forum, I'm apt to think that the question you posted might not have been stated exactly as it was given to you. Or, that the instructor may have wanted to see the equation solved for "y" instead.
    Also, If you needed to find the value of y for many different values of x, it would be much easier to enter my version into a calculator or spreadsheet. Then, all you would need to do is enter new values of x to get corresponding values of y. No extra algebra necessary!
  15. Sep 23, 2010 #14
    It's all part of my Mechanical Engineering HNC, and I know a few people I'm studying with used MS Excel...... but come on, using a spreadsheet isn't really showing that you can do the Math, is it. It's not getting the grey matter working.
    But like you said it's easier for some than it is others... but like Esther Rantzen used to say, 'That's Life'. Thanks again for your input, Keep up the good work, Cheers.
  16. Oct 7, 2010 #15
    Hi, What do I do to rearragne this Equation to make 'I' the subject.....
    144 x 15.71 + I x 15.71 = (144 + I) 14.05
  17. Oct 7, 2010 #16
    What's the Difference between Sine and arcsin? Can I still work out an arcsin problem on my calculator using the sin key?
  18. Oct 7, 2010 #17
    First of all, you should start a new post, since this is a new, unrelated question.
    Arcsine is the inverse of Sine. It finds the angle given a ratio, whereas Sine finds the ratio given an angle. (The ratio being the length of the side opposite the angle divided by the length of the hypotenuse of a right triangle).
    Most calculators use [itex]sin^{-1}[/tex] for the Arcsine function, and is usually a 2nd function above the "sin" key.
  19. Oct 7, 2010 #18
    Redbelly98
    Staff Emeritus
    zgozvrm is correct. Please post new & unrelated questions by starting a new thread.
