Improper integral
  • Thread starter lcam2
Find if the improper integral converges or diverges; If converges find its exact value.
Integral from 0 to infinity of (Xe-x)dX
Using limit properties, i found that the integral was zero.
Does it make sense that the integral converges to zero?? I don't understand.
Answers and Replies
7,033
No, the integral doesn't converge to zero. Show us what you did and we can steer you in the right direction.
CompuChip
4,306
48
If you mean that
[tex]\lim_{x \to \infty} x e^{-x} = 0[/tex]
then yes. But that does not mean that
[tex]\int_0^\infty x e^{-x} \, dx = 0[/tex]
In fact it is not, because [itex]x e^{-x} \not\equiv 0[/itex].
Try integration by parts?
0∫∞(xe^(x ))dx This is the original promblem
And this is what i did
0∫∞(xe^(x ))dx = lim┬(b→∞) 0∫b(xe^x )dx =lim┬(b→∞) (-be^(-b)-e^(-b) )= lim┬(b→∞) (-b)/e^b =0
CompuChip
4,306
48
You forgot the lower boundaries in your partial integration. You get
[tex]\lim_{b \to 0} \left. (-x e^{-x} - e^{-x} \right|_{x = 0}^\infty[/tex]
which is
[tex](-b e^{-b} + 0 e^{-0}) - (e^{-b} - e^{-0})[/tex]
Ok, i see.
Now evaluating the lower limits my new limit is
lim(b→∞) (-b=1)/(e^b)+1
separating the limits and using l'hopitals, my new limits is 1
Is that correct?? Can i separate the limits?? Im not sure if i can do that.
Thanks for all the help
7,033
Ok, i see.
??? What does this mean?
Your antiderivative turns out to be -xe-x - e-x, which you evaluate at b and at 0
[tex](-b e^{-b} - e^{-b} ) - (-0e^{-0} - e^{-0})[/tex]
[tex]\lim_{b \to \infty} (-b e^{-b} - e^{-b} ) - (-0e^{-0} - e^{-0}) = 1[/tex]
The first two terms approach zero in the limit, so you're left with 1.
CompuChip
4,306
48
In particular, what is the = sign doing inside the brackets?
I'm confused with this term in the above expression:
[tex]
-b e^{-b}
[/tex]
when you plug in infinity for b...would you get -infinity * 0...which is undefined or an indeterminate form?
Char. Limit
[tex]
-b e^{-b}
[/tex]
Here's where we get the idea of growth and decay. e^(-b) decays to 0 much "faster" than b grows to infinity. I believe it's usually proven using L'Hopital's rule.
I'm sorry, it was supposed to be (-b-1), there should not be = inside the brackets.
Thanks, your explanation really helped me!
Actually I have a question, can i write equations in Physics forums, it was very hard to write the equation, Does physics forums have an equation bar?? or something like that??
7,033
There's LaTeX, but there isn't an equation bar. If you click Go Advanced, you get an extended menu bar with buttons for doing exponents (X2) and subscripts (X2). There's a [itex]\Sigma[/itex] button that pops open a list of commonly used LaTeX tags.
Related Threads on Improper integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
