Why is momentum conservation always true in a collision?
In summary: The reason for this is that it is easy to miss that there are dissipative forces, and a common mistake is to assume kinetic energy is conserved when it is not. You should always check afterwards to make sure energy is conserved.
Np14
27
Two blocks of mass 2M and M head toward each other sliding over a frictionless surface sliding with speeds 4v and 6v respectively. After the collision the 2m mass is at rest, and the mass M has a velocity of 2V to the right. Was the collision elastic or inelastic?
  • a. Inelastic since kinetic energy wasn't conserved
  • b. Inelastic since momentum wasn't conserved
  • c. Elastic since kinetic energy was conserved
  • d. Elastic since momentum was conserved
K = 1/2mv2, Δp = mv - mvo
I am sure this is an inelastic collision because one of the objects is at rest after impact so that eliminates choices c and d. But my confusion stems from the belief that kinetic energy conservation and (linear) momentum conservation go hand in hand. Can someone please explain why this is not the case?
Is momentum always conserved in linear collisions?
Momentum is always conserved. Kinetic Energy is not necessarily conserved.
I don't agree that you can eliminate c) or d) on that basis.
To add to what @PeroK said: Why don't you just calculate the KE before and after the collision and compare?
For one thing, momentum is a vector quantity, but kinetic energy is a scalar. Example: Two objects heading toward each other (same mass, same speed, moving in opposite directions) and about to collide and stick together.
Before the collision: Momentum = zero. KE ≠ zero.
After the collision: Momentum still = zero. KE = zero.
Likes PeroK
Suppose two identical blocks of mass ##m## have equal speeds ##v## and are moving in opposite directions. They collide, stick together and are at rest after the collision.
The kinetic energy before the collision is ##2 \times\frac{1}{2}mv^2## and after the collision it is zero. Therefore kinetic energy is not conserved.
The linear momentum before the collision is ##mv+(-mv)=0## and after the collision it is still zero. Therefore momentum is conserved.
Clearly the two do not go hand in hand. As @PeroK already noted, momentum is always conserved throughout a collision. That's because it is a consequence of Newton's 3rd law that always holds. Energy is not necessarily conserved and that's because there might be dissipative forces like friction that diverts some of the energy into the generation of heat. If nothing else, if you hear a collision, some of the initial kinetic energy goes into the production of sound waves ...
For future reference: if you deal with a collision problem, you should always conserve momentum. Do not assume that energy is conserved unless there is specific language in the problem indicating that.
Likes Np14 and PeroK
What is impulse and momentum?
Impulse and momentum are two related concepts in physics that describe an object's motion. Momentum is a measure of an object's motion, while impulse is a measure of the change in momentum.
What is the relationship between impulse and momentum?
The relationship between impulse and momentum is that impulse is equal to the change in momentum. This means that a larger impulse will result in a larger change in momentum, and vice versa.
How is impulse calculated?
Impulse can be calculated by multiplying the force applied to an object by the amount of time the force is applied. This can be represented by the equation I = F x Δt, where I is impulse, F is force, and Δt is the time interval.
What is the unit of measurement for impulse and momentum?
The unit of measurement for impulse is newton-seconds (N·s) in the SI system, while the unit for momentum is kilogram-meters per second (kg·m/s). These units can also be represented as joules (J) and newton-seconds per meter (N·s/m), respectively.
What is the principle of conservation of momentum?
The principle of conservation of momentum states that the total momentum of a closed system (one where there are no external forces acting) remains constant. This means that the initial momentum of the system is equal to the final momentum of the system.
