Impulse/force in pounds for the time frame
In summary, the conversation discusses the question of what the maximum impulse force would be on the components/parts of a machine as it lowers and then immediately stops a weight of 100 pounds at 2m/s for 1000mm before lifting it back up at the same speed. The conversation also addresses the force needed to lift the weight from rest and how it would increase every 10th of a second during the lift. The conversation also touches on the issue of force units being measured in both US and SI units. It is suggested that the time interval during the accelerating phase must be about 1 second to stay within the limits of the machine, and it is noted that the conversation involves a man lifting the weight, which can complicate the
  • #351
Thread locked pending moderation.
EDIT: thread will remain locked.
<h2>1. What is impulse?</h2><p>Impulse is a measure of the change in momentum of an object. It is equal to the force applied to an object multiplied by the time for which the force is applied.</p><h2>2. How is impulse calculated?</h2><p>Impulse is calculated by multiplying the force applied to an object by the time for which the force is applied. The unit of impulse is Newton-seconds (N·s) in the metric system, or pound-seconds (lb·s) in the imperial system.</p><h2>3. What is the relationship between impulse and force?</h2><p>Impulse and force are directly proportional to each other. This means that the greater the force applied to an object, the greater the impulse will be. Similarly, the longer the force is applied, the greater the impulse will be.</p><h2>4. How is impulse related to change in momentum?</h2><p>Impulse is equal to the change in momentum of an object. This means that the impulse applied to an object will result in a change in its momentum. The direction of the change in momentum will depend on the direction of the force applied.</p><h2>5. How is impulse measured in pounds for a specific time frame?</h2><p>In the imperial system, impulse is measured in pound-seconds (lb·s). This means that the force applied must be measured in pounds (lb) and the time for which the force is applied must be measured in seconds (s).</p>
1. What is impulse?
11K
  • Mechanics
  • Mechanical Engineering
