- #1
aloshi
- 80
- 0
Hello!
yes is from Sweden and my English is not good, but will try to do as best as possible. My question is:
why can not consider the momentum as the acceleration energy?
I know that:
Impulse is change in momentum which is not the same as energy
Impulse can be expressed either as F * (delta) t or m * (delta) v since it is the same thing. That the expressions are as follows from Newton's 2nd Kraftlag together with the definition of acceleration: (delta) v / (delta) t
but as we move into the energy we see that energy is defined as:
W = mv ^ 2 / 2
if we compare the energy between, thus förendringen Middle two speeds we get that the change in energy is:
http://www.pluggakuten.se/wiki/image...itled11111.jpg
I can not see a big difference between them, the only thing that separates them is that we have abbreviated removed (delta)stretch
but what is the difference between rörelsenergi and momentum:
I couple of things:
An important difference is that momentum is always kept in a collision between two or more objects. The kinetic energy conservation is generally not in a collision.
Another difference between kinetic energy and momentum is that kinetic energy is a scalar (ie, has size but not direction) while the momentum is a vector (ie, both the size and direction)
but I can not really understand what the difference between momentum and kinetic energy (accelerating energy)
I know that:
W = mv ^ 2 / 2
I couple of things:
