Impulse Response
I have an impulse response h(n)=e^(0.1n)*[u(n)-u(n-8)] and an input x(n)={0,1,2,3,0}, how do I find the output y(k)?
[/B]
i don't even know how to solve. should i try convolution or should i substitute the values of x(n) in h(n). and idk why its y(k) instead of y(n) you don't need to put the exact solution. you just need to explain what i need to do. thanks :)[/B]
Answers and Replies
289
For a discrete time LTI (Linear Time Inviariant) system, the output is completely determined by the output and the impulse response, wich is the response to an impulse funtion (often called delta function). d[n] with d[0] =1 and d[x] = 0 if x<>0.
if you know the response to d[n], you know the response to d[n-t], and any input signal is a linear combination of impulse functions with different time shifts.
The way to determine this is the convolution sum. See here for example:
http://www.eecg.toronto.edu/~ahouse/mirror/engi7824/course_notes_7824_part6.pdf
Thanks for your response!
So i just need to convolve x(n) and h(n)? and the answer is y(n)? how will it become y(k) tho?
289
Sorry, I have no idea why they use y[k] and not y[n].
Related Threads on Impulse Response
  • Last Post
  • Last Post
  • Last Post
  • Last Post
