In magnetism, what is the difference between the B and H fields?
  1. Nov 2, 2017 #121
    But inside of a perfect conductor, there is no "polarization/magnetization" by definition. All charges/currents are "free charges/currents" and are at the surface.
    Where does choice come in?
    ...And what would you "shuffle" to change the conclusion you would be unavoidably directed to about the induced surface charges and/or currents on the border of the perfect conductor, e.i., that the field strengths they are tied to are from outside the border alone?
  2. Nov 2, 2017 #122
    The boundary condition which states that the discontinuity in the tangential component of the H at the border between two mediums is equal to the free surface current density J follows directly from the relation
    ∇ x H = Jfree + ∂D/∂t
  3. Nov 2, 2017 #123
    vanhees71
    2016 Award
    Sure, here you made the usual assumptions, treating the conductor as a continuum and map everything to boundary conditions. From a microscopic point of view things are much different, and the OP asked even on the level of in-medium quantum electrodynamics, a topic, I'd recommend only after studying the classical theory and also the vacuum-QED case in detail first.
    For an excellent treatment of classical in-medium electrodynamics, see Landau&Lifshitz vol. VIII.
  4. Nov 2, 2017 #124
    Yes, the usual assumptions in the macroscopic model.
  5. Nov 2, 2017 #125
    And besides, trying to discuss vector H on the quantum level doesn't even make any sense. H is defined as:
    H = B/μ° - M
    And M is by definition a macroscopic value. It is the magnetic dipole moment per unit volume. Undefined on the quantum level, and hence so too is H.
  6. Nov 2, 2017 #126
    ...and so they are the usual assumptions for a good reason-they are the correct assumptions for the subject matter under discussion.
  7. Nov 2, 2017 #127
    ...which is model independent
  8. Nov 3, 2017 #128
    DrDu
    That's not correct. M and P can be defined microscopically. Only in the simplest cases, it is the dipole moment density.
    However, the definition is model dependent, namely, it depends on whether one splits the electric charges into internal and external ones or into bound and free + external. Any of these groups fulfills a continuity equation
    ##\nabla \cdot j =\partial \rho /\partial t ##.
    Introducing the four vector ##j^\mu## with ##j^0=\rho## and ##j^\mu=j_i## for ##\mu \in \{1,2,3\}## and ##i \in \{x,y,z\}##, and ##\partial_\mu## as ##\partial_0=\partial_t##, ##\partial_\mu =-\partial_i##,
    we can write this as
    ##\partial_\mu j^\mu=0##.
    This equation will be fulfilled iff ##j^\mu = \partial_\nu \Pi^{\mu\nu}## where ##\Pi## is an antisymmetric tensor, i.e. ##\Pi^{\mu\nu}=-\Pi^{\nu\mu}##.
    We call it the polarisation tensor.
    It may be parametrized as
    ##\Pi = \begin{pmatrix}
    0 &P_x &P_y &P_z\\
    -P_x& 0 &M_z& -M_y\\
    -P_y &-M_z &0 & M_x\\
    -P_z & M_y & -M_x& 0
    \end{pmatrix} .
    This tensor is not unique, as the solution of ##j^\mu = \partial_\nu \Pi^{\mu\nu}## is defined only up to a solution of the homogeneous problem ##\partial_\nu \Pi^{\mu\nu}=0 ##. I suppose this is what Hendrik meant with the possibility to shuffle terms.
  9. Nov 3, 2017 #129
    DrDu
    As I just laid out, you can shuffle terms between M and P (at least in the time dependent case) and also the choice of J is a matter of convention. E.g. instead of J_Free you may use J_external.
    In QM, a unique distinction between bound and free charges is problematic.
  10. Nov 3, 2017 #130
    vanhees71
    2016 Award
    It is not! What you define as ##\rho_{\text{free}}## and ##\vec{j}_{\text{free}}## and what as polarizations ##\vec{P}## and ##\vec{M}## is more or less arbitrary. You can easily shuffle contributions from the one to the other without changing the physical relevant fields ##\vec{E}## and ##\vec{B}##. Often, of course, there's a "natural choice", but it's still model dependent.
  11. Nov 3, 2017 #131
    How so?
  12. Nov 3, 2017 #132
    When the cylinder is embedded, a secondary layer of bound densities is formed around it which oppose those of the P or M whose influence would otherwise be prevalent. That is why the method will measure H or D rather than E or B
    Too see what I mean you can try a thought experiment using my cylinder method between the plates of a capacitor with a dielectic medium. Density on the cylinder should always be the density as the cap's plates even though E changes when permitivity changes
  13. Nov 3, 2017 #133
    DrDu
    A classical example is the Lindhard dielectric function of the free electron gas, where a gas of electrons is described by a dielectric function, although one would be tempted to treat it as free charges.
    https://en.wikipedia.org/wiki/Lindhard_theory
  14. Nov 3, 2017 #134
    Okay
Have something to add?
Draft saved Draft deleted
Similar Discussions: In magnetism, what is the difference between the B and H fields?
  1. Magnetic H field (Replies: 2)
Loading...
