InWhat Situations Do We Enounter the Golden Ratio?
In summary: The most articles on the golden ratio on the Internet are about what the golden ratio is, and why it is aesthetically pleasing, and how the ratio of the Fibonacci numbers approach the golden ratio.
musicgold
304
Not a homework problem.
What kind of situations/problems are likely to throw up the golden number?
I know what the golden ratio is and am generally familiar with Euclid's work on the number.
As we know, when two quantities, both a function of the same variable, are multiplied, we are bound to get the quadratic function. Similarly, when is one bound to see a golden ratio situation?
In fact, the whole golden rectangle and ratio discussion seems strange to me. I am interested in knowing the kind of problems the ancient Egyptians and Greeks were grappling with when they encountered the golden number.
It would be great if you could point me to a book or website where I can read more on such topics.
Likes Delta2
I am afraid I can't answer directly your questions, probably a more knowledgeable member than me can, but did you read the entry of wikipedia?
https://en.wikipedia.org/wiki/Golden_ratio
It has a ton of references too there.
I know wikipedia articles are usually of average quality but this seems good.
musicgold said:
Homework Statement:: Not a homework problem.
Relevant Equations:: I know what the golden ratio is and am generally familiar with Euclid's work on the number.
Pivotal in the development of early trig tables - ratios of pentagon related angles such as ##18^{\circ}, 36^{\circ}, 54^{\circ}## and ##72^{\circ}##. Used in conjunction with Ptolemy's theorem.
Likes Delta2
The golden ratio occurs often in nature, and in architecture. And the internet is full of references under the search key "golden ratio". Are you looking for something particular?
No, we don't know this. It's true only if the quantities are linear functions in the shared variable, not for arbitrary functions.
At the risk of repeating what can be found in the Wikipedia article, the Greeks were trying to find the most aesthetically pleasing dimensions for a rectangle, such as the shape of the front of temples. They decided that the dimensions should be the ratio of the width to the height should be equal to the ratio of the height to the sum of width and height. I.e., W : L :: L : W + L. If we set W = 1, this leads to the quadratic equation ##L^2 - L - 1 = 0##. The larger root is called the golden ratio and has been given the name ##\phi##. Its value is approximately 1.618.
Successive terms in the Fibonacci Sequence approach ##\phi## in the limit.
Likes Delta2
Thanks.
I, however, feel that these properties of the golden ratio were probably discovered afterwards and that the ancients probably encountered this "weird" quantity while working on something else. For example, how the Greeks encountered the irrational sqrt(2) while trying to quantify the hypotenuse of a 1x1 square, or how they struggled when they tried to double the volume of a cube.
The major point is that in the world of the ancient Greeks, the length of a line corresponded to a number, and the relation between two numbers had been a point that separated such a line (of final length) into two sections. This was what they primarily dealt with. To understand the golden ratio in this regard, have a look at the Wikipedia article https://en.wikipedia.org/wiki/Golden_ratio but do not read it. Look only at the images.
Likes musicgold
One of the roots of ##x^2 -x -1## is ## \frac {1 + \sqrt 5} 2 ## and that = ## \Phi ## .
Usually written as lower-case: ##\phi##.
I dont know if Im mixing things up here, but Im confused that the Greeks considered Irrational numbers somehoe unnatural, re the whole issue with ##\sqrt 2 ## ,somehow include ##\sqrt 5## in a formula for beauty, or even for " Elegance ".
Natural or rational numbers have always been lengths and ratios of lengths to the ancient Greeks. It is all about ratios. The golden cut is defined as a ratio: ##\dfrac{a}{b}=\dfrac{a+b}{a}.##
On the other hand, ##\sqrt{2}## is ##\dfrac{a}{b+b}=\dfrac{b}{a}.##
1. What is the Golden Ratio?
The Golden Ratio, also known as the Divine Proportion, is a mathematical ratio of approximately 1.618. It is often represented by the Greek letter phi (φ) and is found in many natural and man-made structures.
2. How is the Golden Ratio calculated?
The Golden Ratio is calculated by dividing a line into two parts so that the longer part divided by the smaller part is equal to the whole length divided by the longer part. This can also be expressed as (a+b)/a = a/b = φ.
3. In what situations do we encounter the Golden Ratio?
The Golden Ratio can be found in various fields such as art, architecture, nature, and even in the human body. It is believed to create a sense of balance, harmony, and beauty in these structures.
4. Why is the Golden Ratio important?
The Golden Ratio has been studied and admired by mathematicians, scientists, and artists for centuries. It is believed to be a fundamental building block of the universe and is considered a key element in creating aesthetically pleasing designs.
5. Can the Golden Ratio be seen in modern technology?
Yes, the Golden Ratio has been incorporated into modern technology and design, such as in the proportions of computer screens and smartphones. It is also used in website design and user interface to create a visually appealing layout.
  • General Math
  • General Discussion
  • STEM Academic Advising
  • Art, Music, History, and Linguistics
  • New Member Introductions
  • High Energy, Nuclear, Particle Physics
9K
