Incident and refracted angles
  • Thread starter steppenwolf
  • Tags
    Angles
In summary, the conversation discusses a problem with finding the refractive angle of a ray of light incident on a substance with a refractive index of about 1.4. The speaker is unsure if their method of pretending the refractive index was 1 and finding the angle of refraction to be 90 degrees was correct. They plan on asking their teacher for clarification and are also stumped by a geometry problem. The conversation includes some tips for solving the problem, such as checking for a critical angle and using the principle of incidence=reflection when the light is completely reflected.
steppenwolf
ok so this was in my end of unit test today and i have been stressing as to what i should have done, so as it's not really homework you could always just tell me the answer
pretty basic stuff, a ray of light is incident from a substance upon the surface of another substance with n=1. i can't remember the exact refractive index of the first material but it was about 1.4 or something, hmm. anyway, i worked out the incident abgle to be 47 degrees and to find the refractive angle used
sin incident angle x n1 = sin refractive angle x n2
seeing as n2 = 1 then you get
sin refracted angle = sin incident angle x n1
which ended up being about 1.09 or something, ok, a sine>1 ?
well i just pretended it was 1 and so worked out the refracted angle to be total, ie 90 degrees. was this the right thing to do? was this some measurment discrepancy i was supposed to disregard? help, i don't want to wait a month for results to understand this problem!
Wait a month? Why not just go to your teacher and ask?
I cringed at "i just pretended it was 1" but basically, that is what happens. If the angle of incidence and index of refraction
are such that n*sin(theta)> 1 then the light is completely reflected- there is no angle of refraction.
thanks, that's what i thought. i would ask my teacher but i don't know where he lives, in his lab maybe but i doubt it, i will go stake out the science department until he surfaces...
You could look at it as a part of the test... apart from learning physics, they want you to get familiar with the institute... :wink:
Going to class might be a good way of finding your instructor!
Failing that, checking the syllabus he gave you at the beginning of the year, the schedule posted on his office door or even asking the department secretary just might be ways of determining when he is in.
i don't have classes for a few weeks actually!
but thanks anyway, i am now stumped by a certain geometry problem, is it worth a new thread? hmm, alright then!
*goes off to post new thread on particularily nasty geometry shenanigans*
Yep..When doing these problems, when lights going form more dense to less dense, you have to check for the critical angle...and like Halls said, if your angle of incidence is greater than that critical angle, you get reflection...and when it reflects its just incidence=reflection
What is an incident angle?
An incident angle is the angle at which a wave or ray of light hits a surface. It is measured between the incident ray and the normal line perpendicular to the surface.
What is a refracted angle?
A refracted angle is the angle at which a wave or ray of light is bent when it passes from one medium to another. It is measured between the refracted ray and the normal line perpendicular to the surface.
What is the law of reflection?
The law of reflection states that the incident angle and the reflected angle are equal, with both angles being measured from the normal line perpendicular to the reflecting surface.
How is the refracted angle related to the incident angle?
The refracted angle is related to the incident angle by Snell's Law, which states that the ratio of the sine of the incident angle to the sine of the refracted angle is equal to the ratio of the speeds of light in the two media.
What factors affect the incident and refracted angles?
The incident and refracted angles are affected by the properties of the medium through which the wave or ray of light is passing, such as density, temperature, and refractive index. They are also affected by the angle at which the wave or ray approaches the surface.
