Homework Help: Incline plane
  1. Mar 10, 2005 #1
    tony873004
    Can someone tell me if I did this right?
    An object of mass m is hung from a rope that passes over a pulley at the top of a ramp and is attached to a block of mass M.
    (a) Assume m is large enough that the block accelerates up the ramp. Find an expression for the block’s acceleration.
    (b) From your result for part (a), determine the minimum ratio m/M such that the block, once moving, accelerates up the ramp.
    (the diagram is simple, M is on the incline plane and m is hanging straight down)
    [tex]a = \frac{Force}{mass}[/tex]
    [tex]a=\frac{Mg sin\theta + \mu Mg cos \theta -mg}{M}[/tex] (answer for part A)
    Set the force equal to 0
    [tex]Mg sin \theta + \mu Mg cos \theta - mg = 0[/tex]
    [tex]Mg sin \theta + \mu Mg cos \theta = mg [/tex]
    factor out Mg
    [tex]Mg(sin \theta + \mu cos \theta) = mg[/tex]
    the g's cancel
    [tex]m = M(sin \theta + \mu cos \theta)[/tex]
    [tex]m/M = sin \theta + \mu cos \theta[/tex]
  3. Mar 10, 2005 #2
    dextercioby
    AWKWARDLY,the answer to poin b) is correct (the minimum value is the one u found),but the acceleration you find is incorrect,assuming the rope is inextensible (the same tension in it in every point)...
    How about correcting your mistake?
    Daniel.
  4. Mar 10, 2005 #3
    tony873004
    Thanks, Dex.
    I'm guessing that I should have M+m in the denominator of my first answer instead of simply M. They must accelerate at the same rate so should be treated as a single mass.
    By awkardly, did you mean because I had to get the first part to get the second part?
  5. Mar 10, 2005 #4
    dextercioby
    Yes,exactly,you got the point perfectly.Well done!
    Daniel.
  6. Mar 10, 2005 #5
    tony873004
    Thanks, Dextercioby. I'd have turned it in as is if you didn't make me go back and look!
  7. Mar 10, 2005 #6
    dextercioby
    Good thing that u decided to check by posting it here.
    Daniel.
  8. Mar 11, 2005 #7
    tony873004
    You couldn't be more right. We had a mid term today, and this exact problem, but with specific numbers, was on the exam. I'd have missed it had we not gone through it last night!!
