Inclined Plane and box
  • Thread starter jerryez
The owner of a warehouse ask an engineer to design a ramp which will reduce the force necessary to lift boxes to the top of a 1/2 m step. If there is only room enough for a 4 m ramp, what is the maximum factor by which the lifting force could be reduced?
I am not sure how to find the maximum factor?? Could anyone help?
Answers and Replies
tiny-tim
25,832
251
hi jerryez! :wink:
well, the force to lift it without a ramp, vertically upwards (and with zero acceleration), is mgh …
what is the force needed if you use a 4m ramp? :smile:
Hello Tiny-tim
Would the force than be equal to mgsintheta?? I dont think this is right but that is my best guess.
You got it...
Now find theta and compare g to g*sintheta
So theta = 7.2
g = 9.81 m/s(squared)
g*sintheta = 1.23
I still dont understand what the maximum factor by which the lifting force could be reduced is??
rl.bhat
4,433
It is a simple machine.
The mechanical advantage = Load/ effort = Distance traveled by the effort/ Distance traveled by the load. = 4/(1/2)
tiny-tim
25,832
251
hello jerryez! :smile:
(just got up :zzz: …)
The reason for the word "maximum" is because it depends on the angle of the force (and also on the acceleration being zero).
Usually when you push or pull something, your applied force isn't exactly along the slope, and if it's not exact, then you need extra force. :wink:
hmm … guessing will be no good in the exam :redface:
the method to use, as nearly always, is good ol' Newton's second law …
we're assuming no acceleration along the slope
so (let's call that direction "k") (Ftotal).k = ma.k = 0. :wink:
Along with the other things Tim mentioned, maximum would also assume there is no friction. This would make a signficant difference in the real world. So I assume your problem also avoids this variable as well as if you did not pull the mass parallel to the plane or accelerate the mass up the plane.
I am sorry for the intervention. The posters question went unanswered for a while. So I just added that g v. sintheta*g gives you the appropriate ratio. If its force it would be mg v. m*sintheta*g, but since m is on both sides I took an irresponsible shortcut. Sorry.
I think its says the forced reduced by, so using your shortcut I think it would be 1/2 over 4. If it said how much "easier"...
Thank you everyone for your help!! The answer to the problem is 8 I just didnt understand how they got it.
I also see now how the ratio between g and g*sintheta also results in the correct answer.
9.81/1.23 = 7.9
Related Threads on Inclined Plane and box
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
